How to get Google Assistant to show me My Climate Entities
I have a number of Climate entities in my HA (running on i3 NUC)
I have a ZWAVE MS6 which is mounted in my stairwell. It gives me humidity, Light (LUX), and temperature as well as motion detection.
I also have a Pi Zero which I am using to monitor my swimming pool temperature using a DS18B20 and MQTT broker that HA hooks into.
I can view all this in HA
I would also like to be able to get google Assistant on my Google Nest Hub to tell me these if I ask but can’t quite get my head around how to do it so far so am looking for some guidance please.
What I have done so far…
I have grouped all the entities I want under “climate”
I have a Nabu casa subscription and climate shows. When I click on it it gives the entities I wan to have google assistant show when when I ask the NEST to show me climate it thinks it’s a switch and give me a switch icon to turn on.
Ideally I would like to ask google what the pool temperature is?
Can anyone give me some assistance in achieving this please.
30/10/20 I updated to HA 117.0
I am still struggling with this issue. When I click on “Manage Domains” I don’t see “climate”?
I my knowledge here is very limited.
When I read https://www.home-assistant.io/integrations/google_assistant/ it implies that it’s all done automatically when you use Home Assistant Cloud.
If I read this guide https://www.nabucasa.com/config/google_assistant/ it states that climate is an available domain.
Yet it see climate in my group as a switch???
confused.
Please help.
By chance this afternoon I came across the fact that Google Assistant only supports things that have an actions.
So in order to trick it I used the GENERIC THERMOSTAT platform.
# Pool Thermostat
climate:
  - platform: generic_thermostat
    heater: switch.salchlor
    target_sensor: sensor.pool_temperature
ref https://www.home-assistant.io/integrations/generic_thermostat/
This tricks HA & therefore Google Assistant into thinking that the pool temperature sensor is a thermostat and has a switch that it can turn on give specific temperature ranges. The switch I have give in real but does not have a heater connected but an older chlorinator that I sometimes use.
However Climate is one of the managed domains for Nabu Casa and its now visible in the "Managed DomainsI"
And now I can ask Google Assistant what the pool temperature is.
Happy Days!!
