How to get Heiman Siren with ZHA to work
I tried the values today. I use ZHA and it did not do the trick.
Have you been able to make it work from Node-red? Mine is not working. Thanks in advance for your answer,.
Can you share some screenshots? I was able to do the script but nothing happens whe I run it.
Here below the screenshots of my script to turn on the sound and flash.
Of course you need to fill in your own IEEE from the device.
ieee: use own address of the sirene
Options:
strobe: 1 (Strobe ON)
strobe: 0 (Strobe OFF)
mode: 1 (Sirene ON)
mode: 0 (Sirene OFF)
duration: time of the sirene / Strobe in seconds
alarm - yaml
Anybody else having issues with newest HA version and Heimann sirens dropped off from ZHA -network and can not be added/ paired again wih Conbee II?
Never mind, needed to powercycle and put into pairing modes few times the sirens and managed join them to ZHA-network again.
This worked for me.
Is there anyway to stop this? I had duration set to 5 seconds, and it continued past this, I think for about 30 seconds.
But will would like to be able to trigger a stop from HA
Hi Sean,
I use his script to turn it off:
alias: Alarm - Flash en Sirene 01 - Uit
sequence:
  - data:
      duration: 60
      duty_cycle: 2
      ieee: 00:0d:6f:00:XX:XX:XX
      intensity: 2
      level: 1
      mode: 0
      strobe: 0
    service: zha.warning_device_warn
mode: single
icon: mdi:volume-off
Thanks very much :slight_smile:
I cannot seem to get this working. As a test I tried to reconfigure my device and these were the results.
Imgur
This is my script:
office_smoke_alarm_on:
  alias: Office Smoke Alarm on
  sequence:
    - data:
        ieee: '84:2e:14:ff:fe:##:##:##'
        intensity: 2
        mode: 1
        level: 1
        duty_cycle: 2
        duration: 60
        strobe: 1
  mode: single
  icon: mdi:volume-high
I am using
  • ZHA
  • Sonoff Zigbee bridge flashed with tasmota
Any guidance would be appreciated. I am trying to eventually make an automation if my office smoke alarm activates it will sound the siren in the bed rooms.
Hi Hans,
There is a small difference in the spacing, that can be your problem.
The sirene turned on, in my scripts.yaml, see below.
Best regards,
Jacob
alarm_flash_sirene_01_aan:
  alias: Alarm - Flash en Sirene 01 - Aan
  sequence:
  - data:
      duration: 60
      duty_cycle: 2
      ieee: 00:0d:6f:00:XX:XX:XX:XX
      intensity: 2
      level: 1
      mode: 1
      strobe: 1
  mode: single
I bought the Heimen siren in order to pair with conbee 2 stick in deCONZ.
It is working fine but I can only turn on and off.
In the meantime, I bought a CC 2531 Sonoff Zigbee sniffer.
I am wondering if I should use zigbee2mqtt or ZHA from HA to have all data available to customize properly the siren?
Up to now zigbee2mqtt is the one working better as far as I read.
I think and hope, that the siren is added to the ZHA devices and 100% integrated into Home Assistant.
The missing sensors like the battery is nice to have for me.
I use the ZHA and I will wait.
Best regards,
Jacob
The battery works with Z2M .
FYI, support for siren entities in ZHA integration component was just added to Home Assistantā€™s core:
https://github.com/home-assistant/core/pull/60920
https://community.home-assistant.io/t/zha-integration-to-use-siren-entity-platform-for-zigbee-sirens-doorbells-and-chimes/343075
Should make it into HA 2021.12 release https://rc.home-assistant.io/blog/2021/12/03/release-202112/
Update: It did make it into the 2021.21 release so if your device is not seen as a siren (even after remove and re-join it) then it need that specific device will probably need a custom quirk in ZHA Device Handlers, see ā†’ https://www.home-assistant.io/integrations/zha#zha-exception-and-deviation-handling
Also see https://community.home-assistant.io/t/zha-integration-to-use-siren-entity-platform-for-zigbee-sirens-doorbells-and-chimes/343075
Have you tried this siren after the recent update? Iā€™m also using ZHA and looking to buy this siren
Yes. Working fine
    - service: siren.turn_on
        entity_id: siren.siren
        tone: 1
        duration: 65535
        volume_level: 1
Works first time for me, using ZHA and the developer tools - thanks @Jacob_nr.5 or sharing. I got the alarm to stop by issuing the stop command - as the duration of 5 seconds did not work. Now to integrate this with Alarmo!
@gr1nch have you managed to integrate this into alarmo? Mine runs fine with a script and it strobes but i donā€™t seem to be able to integrate it. In actions i am trying to make it call the script.
Not yet @leosedf as I moved from devices (Zbbridge & ZHA (which kept disconnecting clients) to CC2531 + zigbee2mqtt pending a Sonoff ZBDongle-P) and try as I might, the Siren is not getting recognized by the CC2531.
Thank you for your reply.
I couldnā€™t make it work so far, the siren works fine and it strobes if i create a script and run it though.
