Hello, @gr1nch @leosedf have either of you been able to integrate it with Alarmo yet. Looking to buy this siren but need it to work with Alarmo. Thank you!
I havenāt done much work on it, i have a script that runs it perfectly with light but i havenāt managed to run the script from alarmo it says something about a missing key. Probably a configuration error from my side.
Hey @stroodle96 the siren (HS2WD-E) works perfectly for me with HA and Z2M. Iāve not added it to Alarmo yet, but it will be trivial as it is now a switch entity which can be toggled on or off: on is the siren. Youāll need to adapt to your choice of device in Z2M which defines the topic in MQTT.
Entity creation
Example button
I had upgraded my Zigbee adapter to the āSONOFF Zigbee 3.0 USB Dongle Plusā one of the recommended options here.
https://www.zigbee2mqtt.io/guide/adapters/#recommended
I usually try and muddle through and just figure things out - but I cannot get this one! Iām a bit a newb with Z2M admittedly.
I have tried to use your code, slightly updated as below, but the switch entity just always states āUnavailableā.
Can anyone suggest where Iām going wrong?
mqtt:
switch:
- unique_id: house_siren_2_switch
name: "House Siren 2 Switch"
state_topic: "zigbee2mqtt/House Siren 2"
command_topic: "zigbee2mqtt/House Siren 2/set"
availability:
- topic: "zigbee2mqtt/House Siren 2/availability"
payload_available: "online"
payload_not_available: "offline"
payload_on: '{"warning": {"mode": "fire", "level": "low", "strobe_level": "very_high", "strobe": true, "strobe_duty_cycle": 1, "duration": 1 }}'
payload_off: '{"warning": {"mode": "stop"}}'
state_on: "ON"
state_off: "OFF"
icon: mdi:alarm-light
qos: 1
optimistic: true
retain: true
