Where does appdaemon live? What should I delete to fully get rid of it so I can start fresh?
I tried this:
pi@hassbian:~ $ pip3 uninstall appdaemon
Skipping appdaemon as it is not installed.
pi@hassbian:~ $
but yet:
When I try “sudo hassbian-config install appdaemon” - it automatically changes to the update script - so its finding bits and pieces of it…
Also:
pi@hassbian:~ $ sudo hassbian-config show
This is a list over all suites in hassbian-config
If a suite has green color in the name, you have already installed it.
Install scripts: (Usage ‘sudo hassbian-config install suite’)
appdaemon AppDaemon install script for Hassbian.
And sure enough appdaemon is green!
How I installed it:
I tried installing it a few different ways - I didn’t find the Hassbian specific install script until later so first I tried:
pi@hassbian:~ $ sudo pip3 install appdaemon
then I logged in as HomeAssistant and opened its virtual environment
pi@hassbian:~ $ pip3 install appdaemon
then I created a different virtual environment
then I found the Hassbian specific script:
pi@hassbian:~ $ sudo hassbian-config install appdaemon
Neither worked for me completely probably because of the resulting mess so I would like to start over…
However I can’t seem to get rid of the various bits and pieces of appdaemon scattered around…
So that when I try “sudo hassbian-config install appdaemon” - it automatically changes to the update script - so its findig those bits and pie$sbian:~ $ sudo hassbian-config show
Install scripts: (Usage 'sudo hassbian-config install suite')
cloud9 Cloud9 script for Hassbian.
duckdns Setup for Duck DNS auto renewal, and generates SSL certificate.
fail2ban Setup for fail2ban service.
homeassistant Home Assistant install script for Hassbian.
homebridge Homebridge from this system.
pi@hassbian:~ $ hassbian-config --help
hassbian-config
version: 0.11.1
usage: hassbian-config [command] [suite] [options]
where [command] is one of:
install Installs a software [suite].
upgrade Upgrades software [suite].
remove Remove software [suite].
show To see available [suite] for install/upgrade.
log Displays an log of the last operation.
share-log Generates an hastebin link of the last operation.
show-installed Generates a list of installed suites.
pi@hassbian:~ $
Now how do I properly get rid of all of it so I can do a fresh install? Don’t say reformat, don’t say reformat…I mean its not bad of an option but…
is there a way to avoid that?
