Hello!
So recently got the new Ikea Bilresa scrollwheel and experimentet with dimming lights, and figured out how to get smooth dimming working so I thought I should share it here.
First off, make a group of the lights you want to dim in Z2MQTT (or you could ofc dim a single light).
So the trick is make a automation that is triggered for example when a button is held down (or when Current switch position sensors are triggered if using Bilresa. These sensors have to be enabled).
Next step in the automation is to trigger a light or lightgroup with a long transition time, and set brightness_pct: 100, for example:
action: light.turn_on
metadata: {}
entity_id: light.your_light
transition: 5
brightness_pct: 100
Then wait for a trigger, for example long release (long press end):
wait_for_trigger:
- domain: mqtt
device_id: you_device
type: action
subtype: 2_long_release
trigger: device
continue_on_timeout: false
timeout:
hours: 0
minutes: 0
seconds: 10
milliseconds: 0
If you are using the Bilresa scroll wheel, wait for scrolling to stop:
wait_for_trigger:
- trigger: numeric_state
entity_id:
- sensor.bilresa_scroll_wheel_current_switch_position_4_2
for:
hours: 0
minutes: 0
seconds: 0
milliseconds: 400
below: 1
timeout:
hours: 0
minutes: 0
seconds: 1
milliseconds: 0
and then you have to send a MQTT message to Z2MQTT that will tell the lights to stop the transition:
action: mqtt.publish
metadata: {}
evaluate_payload: false
qos: 0
retain: false
topic: zigbee2mqtt/<Light friendly name>/set
payload: |-
"brightness_move": 0
If it does not stop the dimming, make sure that Z2MQTT base topic is zigbee2mqtt and that the lights friendly name is correct.
