How to get state's value?
I created a button named “Watch TV”. It works fine, but in input_boolean where ‘initial’ is ‘off’ instead I would like to get an actual state of media_player.lg_webos_tv_remote. In other words if TV is turned on I need to return value for input_boolean as ‘on’ if TV is off value needs to be displayed as’off’. Can’t figure out how to, maybe someone could enlighten me?
input_boolean:
  watchtv:
    initial: off --> I need to get an actual state value here of media_player.lg_webos_tv_remote
    icon: mdi:television
  - alias: Turn TV on
      platform: state
      entity_id: input_boolean.watchtv
      state: 'on'
      service: homeassistant.turn_on
      entity_id: media_player.lg_webos_tv_remote
  - alias: Turn TV off
      platform: state
      state: 'off'
      service: homeassistant.turn_off
First off this is really weird. You have two input_boolean which are to turn something on/off. You should only need one of those. For your problem you could just configure a automation which triggers on state changes of you media_player component.
Cheers
Thanks, but I dont understand why it is weird. What I want to accomplish is to have a power button which on connect turns on 3 devices (receiver, tv and chromecast). Same on opposite when you press button to disconnect. All would work but I need to have a correct status of button when HA starts.
Another way I was thinking where this scenario would be useful is look there: https://home-assistant.io/components/input_slider/
Line initial:30 If we could get a correct brightness status of the light we could present slider on correct input versus being it always on 30 when light could be shining at 60…
Maybe you want to have a look at the command_line switch which has a status command to read the correct current state?
