Here is my scenario.
My script sends in parallel a notification to 2 mobiles.
Then the notification gets swiped (cleared) one one device.
The event mobile_app_notification_cleared is then sent to HA.
I want to know which phone swiped the notification. I do not want to know which user, but which phone. The user may be logged in on both phones.
Here is an example of the event that is received.
How do I get from there to the name of the mobile?
event_type: mobile_app_notification_cleared
message: blablabla
server_id: "2"
webhook_id: 12345678890abcdefghijklmopqrstubvwxyz1234567890
device_id: 1244567890abcdefgh
origin: REMOTE
time_fired: "2025-02-24T20:14:38.425183+00:00"
context:
parent_id: null
user_id: 12345567890123456123456789012345
If you are listening for the event in the same script, you would use a Wait for trigger then use the wait
variable to access the data:
{{ device_attr(wait.trigger.event.data.device_id, ānameā) }}
There doesnāt seem to be a way to get the device name from mobile device ID that is available.
To test your suggestion, I tested this dummy script:
sequence:
- action: notify.mobile_app_myphone
metadata: {}
message: test123
- wait_for_trigger:
- trigger: event
event_data: {}
metadata: {}
message: "{{ device_attr(wait.trigger.event.data.device_id, 'name') }}"
alias: ZZZZZZZZZZZ
description: ""
But it doesnāt work. Thereās an error trying to find the name:
Erreur : string value is None for dictionary value @ data['message']
In fact, I could have been more clear. What I really want to do, is wait for a trigger where a specific phone will clear the notification.
So is there a way to programmatically find the device_id I am looking for in the wait for trigger event, or should I necessarily establish manually a mapping in advance?
It looks like you will need to set up a mapping of your ownā¦ I canāt find any way to get it directly from the device ID provided in mobile app events.
You may want set it up as a script of itās own so you have a single place you can query if you plan on using the data in other scripts and automations.
The following script example is from @petro, the full discussion can be found in the discord link above:
alias: Resolved Device ID
fields:
device_id:
description: The mobile device id passed from the automation trigger
example: d818035824cf47ea
variables:
devices:
'd818035824cf47ea': Josh
'009a0965d73ee8f7': MJ
resolved_device_id: >
{{ {'value': devices.get(device_id, 'unknown')} }}
sequence:
- stop: End
response_variable: resolved_device_id
So your test script would become:
sequence:
metadata: {}
message: test123
- alias: Wait for notification to be cleared
timeout: "00:02:00"
wait_for_trigger:
- trigger: event
event_data: {}
- condition: template
value_template: "{{ wait.trigger is not none }}"
- action: script.resolved_device_id
device_id: "{{wait.trigger.event.data.device_id}}"
response_variable: mobile_name
metadata: {}
message: "{{ mobile_name.value }}"
alias: ZZZZZZZZZZZ
description: ""
IIRC, the cleared event is only posted when the message is cleared without being opened, so you might want to keep that in mind if you find you arenāt getting as many triggers as you expect.
In fact the cleared event is sent regardless of āopeningā the notification or not.
I just found a solution for my problem. Yours is interesting, but in my particular use case (which I did not specify, I am a bad person), it is a script that is called twice in parallel. The script sends the exact same actionable notification to 2 phones. It is not the notify command that is directly called in parallel.
This allows the script to āpingā the phone with the confirmation option and get the device_id once the notification is sent.
This way, when the notification is cleared, each of the 2 instances of the script will be able to discriminate if it is for its own instance of the notification or not, and then continue with appropriate actions for the one that has been swiped, but continue waiting for the other one.
Hereās the test script for the āpingā thing:
sequence:
metadata: {}
message: test123
confirmation: true
actions:
- action: action1
title: Done
- action: action2
title: Cancel
- wait_for_trigger:
- trigger: event
event_type: mobile_app_notification_received
event_data: {}
enabled: true
- variables:
this_device: "{{ wait.trigger.event.data.device_id }}"
- wait_for_trigger:
- trigger: event
event_data:
device_id: "{{ this_device }}"
metadata: {}
message: "{{ this_device }}"
alias: ZZZZZZZZZZZ
description: ""
Incidentally, I get the link between āmyphoneā and the device_id, on the fly, without any pre-mapping.
Mh. What I thought was a solution is not in fact a working one. Thatās because the wait for trigger event mobile_app_notification_cleared
will not discriminate which phone it comes from.
And Iām certainly guilty of the XY problem here.
In case someone has a similar issue:
My goal was to have a script that is run twice, from a single āin parallelā command. This script will send an actionable notification to 2 phones. If one of them clicks on āDoneā or āCancelā, it will be done or cancel for both. But if one of them dismisses the notification, the dismissal will be just for that specific phone.
The way to do it is to use the tag option and define it as being phone specific, while defining the āDoneā and āCancelā actions in a non phone specific manner.
Hereās a model of the code.
sequence:
- variables:
action_1: "{{ 'done' ~ context.id }}"
action_2: "{{ 'cancelled' ~ context.id }}"
tag: "{{ myphone ~ context.id }}"
- action: notify.mobile_app_{{ myphone }}
message: test123
tag: "{{ tag }}"
actions:
- action: "{{ action_1 }}"
title: Done
- action: "{{ action_2 }}"
title: Cancel
alias: Send notification
- wait_for_trigger:
- alias: goal_completed
event_type: mobile_app_notification_action
event_data:
trigger: event
- alias: goal_cancelled
event_data:
trigger: event
- alias: Notification dismissed
event_data:
tag: "{{ tag }}"
trigger: event
alias: zzzzdemo
description: ""
fields:
myphone:
selector:
select:
options:
- John
- Johnny
- Jonas
