ashscott
(Ash)
February 7, 2025, 10:22am
1
I have this graphic on my front end that shows the contents of LPG gas bottles and which bank is in use.
I was using six images to show content based on rough consumption calculations.
I now have a 0-100% sensor, the value of which I’d like to use to show the bottles emptying over time.
Essentially, I suppose this amounts to a custom gauge with a coloured rectangle that increases in height with the sensor value. I can mask the rectangle to get the shape.
I can handle the graphics, but I need help creating the gauge without resorting to 100 images.
Is it possible to create such a thing?
Where can I start?
Did you give up on this thread?
So, just switched from hot water tank to GAS heating using LPG bottles, and am now looking for a reliable solution for measuring the bottle levels.
As I understand, the best solution for this will be using “scales” and weighing the bottles? Has anyone done this and are there any other methods to doing this?
I am looking at getting 8 of these 50kg Load Cells,
Load Cell Weighing Sensor | ePartners NZ
Just not sure if this will actually be a reliable solution based on the price of these load ce…
ashscott
(Ash)
February 7, 2025, 10:54am
3
Quite the opposite. It’s having this in place that’s made the sensor available for me to develop the graphic.
Previously, I was calculating the contents from the manufacturer’s consumption figure, generator load and run time to estimate bottle contents.
Now, with weighing, I accurately know the contents.
Its definitely doable without having to use of any images. The iif statements( updates made iif obsolete ) in the code need updated, but that’s an easy change.
I use the Mopeka monitoring system with their WiFi bridge and found it to be a solid addition to my HA.
I built a custom:button-card where the color and gas level are reflected in the icon.
[chrome-capture-2024-4-14 (1)]
Card code
type: custom:button-card
entity: sensor.propane_2
show_state: false
show_name: false
custom_fields:
pct:
card:
tap_action: none
show_state: true
Another method that could be applied…
Hi All,
Currently working on a EV charging/vehicle dashboard and i’m a bit stuck trying to create a visual that shows the amount of charge the car has remaining. Ideally I would like it similar to that of the native car app as it looks clean and does a good job of showing how much charge is left at a glance.
In a nutshell, the native app has a transparent image of the vehicle, then for each percentage of charge, it shades the car in with green. So for 10% charge left, 10 percent of the vehicle…
Can you share your current card code?
ashscott
(Ash)
February 7, 2025, 2:23pm
6
Here’s the current card, as requested.
type: vertical-stack
cards:
- type: custom:mushroom-chips-card
chips:
- type: entity
entity: input_boolean.right_bottle_test
tap_action:
action: toggle
content_info: name
- type: entity
entity: input_boolean.left_bottle_test
tap_action:
action: toggle
content_info: name
- type: entity
entity: input_boolean.lpg_valve_status_test
tap_action:
action: toggle
content_info: name
alignment: center
- type: picture-elements
image: /local/images/lpg_bottles/background-dark.png
elements:
- type: image
entity: sensor.lpg_bottle_in_use_level
style:
left: 50%
top: 50%
width: 100%
state_image:
Bothfull: /local/images/lpg_bottles/4_full.png
Right75: /local/images/lpg_bottles/right-75.png
Right50: /local/images/lpg_bottles/right-50.png
Right25: /local/images/lpg_bottles/right-25.png
Rightempty: /local/images/lpg_bottles/left-full.png
Leftfull: /local/images/lpg_bottles/left-full.png
Left75: /local/images/lpg_bottles/left-75.png
Left50: /local/images/lpg_bottles/left-50.png
Left25: /local/images/lpg_bottles/left-25.png
Leftempty: /local/images/lpg_bottles/right-full.png
- type: image
style:
left: 50%
top: 50%
width: 100%
state_image:
Right: /local/images/lpg_bottles/right_in_use.png?v=2
Left: /local/images/lpg_bottles/left_in_use.png?v=2
Both: /local/images/lpg_bottles/both_in_use.png
- type: image
entity: sensor.lpg_valve_changeover_sensor
style:
left: 50%
top: 50%
width: 100%
state_image:
rightempty: /local/images/lpg_bottles/right_arrow.png
leftempty: /local/images/lpg_bottles/left_arrow.png
bothfull: /local/images/lpg_bottles/bothfull.png
- type: image
entity: input_select.generator_engine_state
style:
left: 50%
top: 50%
width: 100%
state_image:
Running: /local/images/lpg_bottles/feed-arrow.png
Ready: /local/images/lpg_bottles/nofeed-arrow.png
Exercising: /local/images/lpg_bottles/nofeed-arrow.png
Cranking: /local/images/lpg_bottles/nofeed-arrow.png
- type: state-label
entity: sensor.available_run_days_based_on_last_outage_consumption
title: Days remaining
prefix: "Days remaining: "
hold_action:
action: more-info
style:
top: 97%
left: 52%
font-size: 15px
- type: entities
entities:
- entity: sensor.left_lpg_bottle_level
- entity: sensor.right_lpg_bottle_level
- entity: sensor.lpg_bottle_in_use
- entity: sensor.combined_lpg_bottle_levels
- entity: sensor.lpg_bottle_in_use_level
- entity: sensor.lpg_valve_changeover_sensor
- entity: sensor.generator_estimated_fuel_in_tank
ashscott
(Ash)
February 7, 2025, 2:24pm
7
This is excellent. I’ll have a goat adapting it. Thank you.
