So today i found a struggle.
I try to group some lights, so I can control them all from one spot.
Easy, you would think. But what ever I do, I can’t get it right.
# MiLight integration
light:
platform: limitlessled
bridges:
- host: 192.168.178.24
groups:
- number: 1
type: rgbww
fade: true
- number: 2
type: rgbww
fade: true
- number: 3
type: rgbww
fade: true
- number: 4
type: rgbww
fade: true
- host: 192.168.178.44
groups:
- number: 1
type: rgbww
fade: true
- number: 2
type: rgbww
fade: true
- number: 3
type: rgbww
fade: true
- number: 4
type: rgbww
fade: true
- host: 192.168.178.92
groups:
- number: 1
type: rgbww
fade: true
- number: 2
type: rgbww
fade: true
This is my configuration.yaml part, where the lights are defined. I can’t change anything in this, this format is mandatory for LimitlessLED config.
Because light is defined, and inside it also groups, no any normal way of grouping them elsewhere is working. File editor and configuration checker won’t let me pass, if I create a group of them in groups.yaml, I think, because this config already uses groups.
Light Group - Home Assistant won’t work, whatever I try, i get Duplicate errors.
I found this: Limitlessled control all groups
Interesting, but that makes a group of the four groups made under one controller. I need to group lights from all three controllers together.
Anyone knows, how to achieve this?
