Darkyputz
(Darkyputz)
November 5, 2024, 8:17pm
1
Hello…
I have one of those esp01 2 relay boards and i have it working just fine. But when i want to turn the relay on or off, i have to toggle the switch…
Is there a way to have just a button and it does trigger the on and short after the off again?
The logic what it does is in esphome…i would just need to trigger that routine
sun:
latitude: 46.0931
longitude: -72.8054
on_sunrise:
- elevation: 0.8°
then:
- switch.turn_on:
- delay: 20s
- switch.turn_off:
on_sunset:
- elevation: -4°
then:
- switch.turn_on:
- delay: 20s
- switch.turn_off:
You can use button
, f.e.:
sun:
latitude: 46.0931
longitude: -72.8054
on_sunrise:
- elevation: 0.8°
then:
- button.press: button_on_sunrise
button:
name: Button on Sunrise
on_press:
- switch.turn_on:
- delay: 20s
- switch.turn_off:
As well You can move auto_off logic directly to switch:
button:
on_press:
- switch.turn_on:
switch:
- platform: gpio # or other
on_turn_on:
- delay: 20s
- switch.turn_off:
Now even using a switch
it will go off after delay.
Darkyputz
(Darkyputz)
November 6, 2024, 2:11pm
5
Cool thing…
Cause i was looking for, was to trigger the logic…
This will most likely work…
Will try this weekend when i have time…
Thx alot…
Darkyputz
(Darkyputz)
November 7, 2024, 4:35pm
6
I tried it out and its awesome…
Thx a lot
