Apologies if I have this in the wrong place. Most of my experience so far has been trawling the wealth of information here via Google…
Short version - is there a way to reference “me” with-in a sensor value template without needing to write the sensor name?
I’m trying to put together some re-usable packages related to handling Linux RAID and trying to use anchors to reduce the sheer volume of copy/paste that can come up if you have several RAID devices.
So, at the moment it works as follows:
Machine with the RAID array regularly pushes a JSON version of /proc/mdstat via MQTT to a single queue on HA.
On HA there is one MQTT sensor that receives all of the information to the json_attributes_topic. This sensor has a certain amount of stuff defined and anchored to allow re-use across other topics.
For the purposes of usability in HA, each array is defined as a separate sensor, sharing the original json_attributes topic, but tweaked for that array.
sensor raidCommon: &raidCommon
platform: mqtt
state_topic: "/home/server/mdstat_json/sink"
json_attributes_topic: "/home/server/mdstat_json"
icon: "mdi:nas"
## MQTT sensors for each of the RAID devices - absorbs the originally received JSON in to the various sensors
sensor md100:
<<: *raidCommon
value_template: >-
{% set whoami = "sensor.md100_raid" %}
{% set isActive = state_attr(whoami, "active") %}
{% set isReadOnly = state_attr(whoami, "read_only") %}
{% set isDegraded = (state_attr(whoami, "status").non_degraded_disks < state_attr(whoami, "status").raid_disks) %}
{%- if not isActive -%}Inactive{%- else -%} {%- if not isReadOnly and not isDegraded -%}Active{%- else -%}Impaired{%- endif -%} {%- endif -%}
json_attributes_template: "{{ value_json.devices.md100 | tojson }}"
You can see the copy/paste issue there if there are more raid devices and problems if the value template is updated or changed later…
Is there a way to reference “self” with-in the template? i.e. Could I get rid of the whoami and just have the remaining items refer to “me” or similar?
Or if someone has an alternative approach entirely that simplifies it please shout :).
