because my ESP8266 ist battery powered, I managed to measure the battery voltage, so that I could be informed about emtpy battery for recharging. Using the analog input, I’m measuring the battery voltage. But on the user Interface I would like to see the percentage of battery level. Therefore I wrote the following code:
# Sensor for measuring battery voltage
- platform: adc
pin: A0
update_interval: 2s
filters:
# Factor for converting range 0.0-1.0 Volts into 3.01-4.15 Volts.
- multiply: 4.554
text_sensor:
update_interval: 2s
lambda: !lambda |-
float volt = id(BatteryVoltMeasurement).state;
// the following lines convert the voltage level to percent range
float moveToZero = -3.01;
float skalingFactor = 87.43;
float percent = (volt+moveToZero) * skalingFactor;
if(percent < 0.0) {
percent = 0.0;
} else if (percent > 100.0) {
percent = 100.0;
std::stringstream ss;
ss << std::fixed << std::setprecision(0) << percent << "%";
std::string s = ss.str();
return {s};
As you can see, I’m using stringstream for converting a floating point value into a string value without any decimal places.
Now, my question is: How can I include C++ header files like inside of the yaml file?
I only found the following workaround:
I added a custom header file to the includes in my yaml file:
esphome:
includes: std_includes.h
And the file std_includes.h contains:
#include <sstream> // std::stringstream
#include <iostream> // std::fixed
#include <iomanip> // std::setprecision
But I believe there is a way doing that inside of the yaml file without the overhead of adding an extra include file.
