Because I almost pulled out all of my hair after a few weeks of trying, I hope someone can help to point me in the right direction on how to insert a variable in a value_template that is used in a MQTT publish script.
TL/DR;
The line below:
"value_template": "{{ "{{ value_json.outlets[0].current }}" }}",
returns a correct value of 0.043 (measured current of the first outlet of the PDU).
When I add that line and adapt it so I can use it in a repeat loop, the line below:
"value_template": "{{ "{{ value_json.outlets[repeat.index - 1 ].current }}" }}",
returns nothing.
In the trace log, I see
value_template: '{{ value_json.outlets[repeat.index - 1].current }}'
The pointer variable repeat.index is shown instead of it numerical value! How can make it happen that the numerical value is shown instead of the pointer variable repeat.index (minus 1)?
Thank you.
Johan
A bit more context
I have a PDU (Power Distribution Unit) with MQTT support. The idea is to write a MQTT discovery script bundle so I can monitor and manage the PDU from HA. Writing that MQTT discovery script bundle worked, but I wanted to ābeautify itā. Instead of writing a script for each outlet, I hoped to write a repeat script. So far that did not work.
On MQTT topic de/gudesystems/epc/00:19:32/device/telemetry, the PDU publishes each 60 seconds telemetry data in JSON format such as below:
{"type": "telemetry", "portstates": [{"port": "1", "name": "Switch", "state": 1},{"port": "2", "name": "zbridge", "state": 1},{"port": "3", "name": "Fiber, Router", "state": 1},{"port": "4", "name": "Nestor", "state": 1},{"port": "5", "name": "WiFi", "state": 1},{"port": "6", "name": "UNIX box 1", "state": 1},{"port": "7", "name": "UNIX box 2", "state": 1},{"port": "8", "name": "Power Port", "state": 1}], "ovp_state": [1], "line_in": [{"voltage": 232.070,"current": 0.043,"freq": 49.99,"phase": 53.60,"act_pow": 6.0,"react_pow": 7.0,"app_pow": 9.0,"pow_fact": 0.631,"tot_energy": 1.521,"res_energy": 1.516,"res_time": 1424021,"res_current": 0.0003}], "outlets": [{"voltage": 232.060,"current": 0.000,"freq": 49.99,"phase": -7.20,"act_pow": 0.0,"react_pow": 0.0,"app_pow": 0.0,"pow_fact": 1.000,"tot_energy": 1.010,"res_energy": 0.995,"res_time": 1424021},{"voltage": 232.060,"current": 0.043,"freq": 49.99,"phase": 53.40,"act_pow": 6.0,"react_pow": 7.0,"app_pow": 9.0,"pow_fact": 0.635,"tot_energy": 0.813,"res_energy": 0.789,"res_time": 1424021},{"voltage": 232.030,"current": 0.000,"freq": 49.99,"phase": 7.20,"act_pow": 0.0,"react_pow": 0.0,"app_pow": 0.0,"pow_fact": 1.000,"tot_energy": 0.293,"res_energy": 0.260,"res_time": 1424021},{"voltage": 232.070,"current": 0.000,"freq": 49.99,"phase": 101.60,"act_pow": 0.0,"react_pow": 0.0,"app_pow": 0.0,"pow_fact": 1.000,"tot_energy": 0.258,"res_energy": 0.216,"res_time": 1423721},{"voltage": 232.080,"current": 0.000,"freq": 49.99,"phase": -49.30,"act_pow": 0.0,"react_pow": 0.0,"app_pow": 0.0,"pow_fact": 1.000,"tot_energy": 0.268,"res_energy": 0.217,"res_time": 1423721},{"voltage": 232.070,"current": 0.000,"freq": 49.99,"phase": -63.60,"act_pow": 0.0,"react_pow": 0.0,"app_pow": 0.0,"pow_fact": 1.000,"tot_energy": 0.278,"res_energy": 0.218,"res_time": 1423721},{"voltage": 232.110,"current": 0.000,"freq": 49.99,"phase": -58.10,"act_pow": 0.0,"react_pow": 0.0,"app_pow": 0.0,"pow_fact": 1.000,"tot_energy": 0.287,"res_energy": 0.218,"res_time": 1423721},{"voltage": 232.100,"current": 0.000,"freq": 50.00,"phase": -23.30,"act_pow": 0.0,"react_pow": 0.0,"app_pow": 0.0,"pow_fact": 1.000,"tot_energy": 0.295,"res_energy": 0.216,"res_time": 1423721}], "ts": 1767305309}
For now, everything runs in a test environment, so I am free to experiment.
The per outlet script
The script below works:
alias: Outlet 1 Current
action: mqtt.publish
metadata: {}
qos: "0"
retain: false
topic: homeassistant/sensor/pdu_001932/outlet_1_current/config
payload: |-
"name": "PDU Outlet 1 Current",
"unique_id": "pdu_001932_outlet_1_current",
"state_topic": "de/gudesystems/epc/00:19:32/device/telemetry",
"value_template": "{{ {{ value_json.outlets[0].current }}" }}",
"state_class": "measurement",
"device_class": "current",
"unit_of_measurement": "A",
"device": {
"identifiers": ["pdu_001932"]
enabled: true
The script with a repeat loop
This PDU has 8 outlets. I hoped I could create a script such as:
alias: Define Current measurement of outlets 1 through 8
repeat:
count: 8
sequence:
- action: mqtt.publish
metadata: {}
qos: "0"
retain: true
topic: >-
homeassistant/sensor/pdu_001932/outlet_{{ repeat.index
}}_current/config
payload: |-
"name": "PDU Outlet {{ repeat.index }} Current",
"unique_id": "pdu_001932_outlet_{{ repeat.index }}_current",
"device": {
- delay:
hours: 0
minutes: 0
seconds: 1
milliseconds: 0
The repeat.index pointer starts at 1, but the array pointer starts at 0, so I need to subtract 1 (I tried repeat.index0, but that did not work).
For some reason, when I use in HA for value_template "{{, I get an UndefinedError: āvalue_jsonā is undefined. When I do it like I did in my scripts "{{ "{{, I donāt get the error and I get results back that I expect.
If I look at the trace result for the latter script, I see (for the first iteration):
MQTT 'Publish'
Iteration 1
Executed: January 1, 2026 at 10:30:51 PM
Result:
params:
domain: mqtt
service: publish
service_data:
qos: '0'
retain: true
payload:
name: PDU Outlet 1 Current
unique_id: pdu_001932_outlet_1_current
state_topic: de/gudesystems/epc/00:19:32/device/telemetry
state_class: measurement
device_class: current
unit_of_measurement: A
device:
identifiers:
- pdu_001932
target: {}
running_script: false
To my surprise, the pointer variable name repeat.index is shown, instead of its expected numerical value 1 - 1 = 0.
Thank you for pointing me in the right direction.
Johan
