Hi everyone
I just received a conbee usb stick and a aqara temperature zigbee sensor. I already have my Rp3 running Hassbian.
How do I install the conbee usb stick on the Pi so I can configure it and pair my temp sensor with HomeAssistant?
Was I wrong in assuming I could have it all running on the Pi ?
Thanks in advance
Trying to be helpful while remaining slightly unhelpful. This guide is in Swedish and you might want to check the version numbers. But this is what I used to get it running on my Hassbian in headless mode. install
https://snillevilla.se/styr-ikea-tradfri-lampor-i-home-assistant-med-conbee/
I don’t have any temp sensors on my setup, but it should be pretty straight forward if they’re supported.
Exactly what I needed to get started, thank you
