How to install swipe card properly?
I hope someone can help me.
I have installed the swipe card trough HACS.
The file swipe-card.js is inside the config\www\custom-lovelace\swipe-card folder.
Based on the install instruction, I should insert the following to the lovelace config:
resources:
  - url: /local/custom-lovelace/swipe-card/swipe-card.js
    type: module
But where is the lovelace config located and does dwains dashboard use a different config file?
I have inserted this code both to the configuration.yaml in the root folder an to the dwains-dashboard/configs/settings.yaml file, but in the frontend I get the error “custom element doesn’t exist: swiper-card”.
Settings - dashboards - upper right dots - resources
In my experience, when using HACS there is no need to register resources manually, it is already done by HACS.
Correct, but even though the Swipe Card is present in HACS, it is not really installed by HACS. It is a manual download of a JavaScript file, followed by a manual addition of the Resource. Reason being that this custom card is archived and no longer actively maintained. Cheers!
