How to install thread and matter on HA core
Prerequisites
  • Home Assistant Core (venv, Python 3.14)
  • Ubuntu Linux (NUC or similar)
  • nRF52840 USB dongle (Nordic Semiconductor)
  • Android or iPhone with HA Companion App
1. Flash the nRF52840 as OpenThread RCP
Download firmware:
Download flashing tool:
Flashing:
  1. Hold the reset button while inserting the dongle → LED blinks red
  2. Launch nRF Connect for Desktop → open Programmer
  3. Select device → load ot-rcp-USB.hex → Write
Verify success:
dmesg | grep -i nordic
# Expected output: "ASA Thread Co-Processor"
2. Install OpenThread Border Router (OTBR)
sudo snap install openthread-border-router --beta
Set permissions:
sudo snap connect openthread-border-router:raw-usb
sudo snap connect openthread-border-router:network-control
sudo snap connect openthread-border-router:firewall-control
sudo snap connect openthread-border-router:avahi-control avahi:avahi-control
Find LAN interface:
ip link show
# e.g. enp2s0, eth0, eno1
Configure:
sudo snap set openthread-border-router radio-url="spinel+hdlc+uart:///dev/ttyACM0?uart-baudrate=460800"
sudo snap set openthread-border-router infra-if="enp2s0"   # adjust to your LAN interface
sudo snap set openthread-border-router webgui-port=82
sudo snap set openthread-border-router autostart=true
Start:
sudo snap start openthread-border-router
Form a Thread network:
sudo openthread-border-router.ot-ctl dataset init new
sudo openthread-border-router.ot-ctl dataset commit active
sudo openthread-border-router.ot-ctl ifconfig up
sudo openthread-border-router.ot-ctl thread start
Check status:
sudo openthread-border-router.ot-ctl state
# Expected output: leader
Reference: How to set up OpenThread Border Router on Ubuntu - Matter on Ubuntu documentation
3. Install python-matter-server
(Note: in the future, you can install also the new matter-js server)
source ~/homeassistant3.14/bin/activate
pip install "python-matter-server[server]"
Create systemd service:
sudo nano /etc/systemd/system/matter-server.service
Content:
[Unit]
Description=Matter Server
After=network.target
[Service]
User=nuc
ExecStart=/home/nuc/homeassistant3.14/bin/matter-server \
  --storage-path /home/nuc/.matter-server \
  --port 5580 \
  --enable-test-net-dcl \
  --paa-root-cert-dir /home/nuc/.matter-server/credentials
Restart=on-failure
[Install]
WantedBy=multi-user.target
Create directory and start service:
mkdir -p /home/nuc/.matter-server
mkdir -p /home/nuc/.matter-server/credentials
sudo systemctl daemon-reload
sudo systemctl enable matter-server
sudo systemctl start matter-server
Check status:
sudo systemctl status matter-server
4. Install HA Integrations
Matter Integration
  1. Settings → Integrations → + Integration → Matter
  2. Enter the Matter Server URL: ws://localhost:5580/ws
OpenThread Border Router Integration
  1. Settings → Integrations → + Integration → OpenThread Border Router
  2. Enter the OTBR URL: http://localhost:8081
5. Sync Thread credentials to phone
Thread credentials must be transferred to the phone before new Matter devices can be commissioned.
Android:
  1. Open HA Companion App
  2. Settings → Companion App → Troubleshooting
  3. Select Sync Thread credentials
iPhone:
  2. Settings → Devices & Services → Thread Integration
  3. Configure → Send credentials to phone
6. Add a new Matter device
  1. Power up the device → it automatically enters pairing mode
  2. A pop-up appears on your phone prompting you to scan the QR code
  3. If no pop-up: Settings → Matter → Add device → Add Matter device
  4. Select “No, it’s new”
  5. Scan the QR code on the Matter device
Architecture overview
Matter device (e.g. IKEA sensor)
      ↕ Thread (802.15.4 radio)
nRF52840 dongle (RCP – radio only)
      ↕ USB / Spinel protocol
OTBR Snap (Thread stack + IPv6 routing)
      ↕ LAN / IPv6
python-matter-server (port 5580)
      ↕ WebSocket
HA Matter Integration
HA entities
Channel recommendations (avoiding interference)
Zigbee, Thread and WiFi all use 2.4 GHz and can interfere with each other.
Protocol Recommended channel
WiFi 1 or 6
Zigbee 15
Thread 25 or 26
Change Thread channel:
sudo openthread-border-router.ot-ctl channel 26
Known issues
No module named 'chip.exceptions'
# instead of just: pip install python-matter-server
OTBR not responding (no response from RCP)
  • Check that the correct port is used: dmesg | grep tty
  • Add the uart-init-deassert parameter:
sudo snap set openthread-border-router radio-url="spinel+hdlc+uart:///dev/ttyACM0?uart-baudrate=460800&uart-init-deassert"
sudo snap restart openthread-border-router
Matter device cannot be re-commissioned
  • Perform a factory reset on the device (device-specific procedure)
  • Then commission again via HA
Before someone goes down a possibly unsupported rabbit hole, is this using the deprecated Home Assistant Core installation method that is no longer supported? If so, caveat emptor…
If somebody already has HA running as a core installation, there is no need to warn him. This is not a recommendation to install HA in core mode.
