How to integrate remote GPIO in HA container?
I have got HA running in a Docker container.
HA seems to works normally except that switch for my remote GPIO never appears in the device list.
I have followed (Raspberry Pi Remote GPIO - Home Assistant )
My configuration yaml, ends with:
# GPIO Raspberry
 switch:
   - platform: remote_rpi_gpio
     host: rpi.local
     ports:
       23: Relay_1
       24: Relay_2
GPIO are working outside HA.
Logs show no error
In the HA documentation, I am not sure about this note and do not know how to use it:
Note that for virtual environments you may need to set an environment variable when starting the environment to set the pin factory, example:
Environment = GPIOZERO_PIN_FACTORY=pigpio PIGPIO_ADDR=YOUR_RPi_IP_ADDRESS
Home Assistant 2022.11.4 Frontend 20221108.0 - latest
installed on a raspberry pi3 with Docker
