Hej Guys,
hope y’all doing good.
I bought the named thermostates.
According to the compatibility database they work with ZHA.
https://zigbee.blakadder.com/Tuya_TV02.html
Installing wasn’t a big issue but I only have one entity update.stube_thermostat_rechts_firmware that’s it. no climate. nothing.
I have reset the device no success. Restart of HA, or the complete VM. Same result.
Do you guys have any ideas?
Cheers from Hamburg
Armin
Uff. Thanks for the link.
Is there a “for dummies” version.
All I can see is like egyptian hyroglyphs.
Sorry. I’m new to this topics.
Found something.
Create a Folder:
\homeassistant\config\custom_zha_quirks
Set link in configuration.yaml:
zha:
custom_quirks_path: /config/custom_zha_quirks/
Download the quirk file into that folder:
zha-device-handlers/zhaquirks/tuya/tuya_trv.py at ce57a931b02598f59a033d04944cf7e35a7546d5 · zigpy/zha-device-handlers · GitHub
Restart Home Assistant.
Done.
Many thanks for that great work. There is a lot of code in this file.
I take it that it works for you? I read through too fast, for some reason I thought you had an additional model. We should be good.
Works very well.
Thanks a lot.
Found out that just a restart of Home Assistant is not enough.
I needed to reconnect the valves too.
