Hello, all,
I am relatively new to HA and want to integrate my Wyze Cam v3 into my HA install. I’ve looked into it, and it seems there are two main options: Install RTSP on the camera via MicroSD, or install the Docker Wyze Bridge from HACS. However, RTSP seems to be “under construction” by Wyze and files are not available. I’ve tried the Docker Wyze Bridge, configuring my username, password, api ID, and api key in both the Web UI and under the configuration tab under “unused options” or whatever it’s called. However, it never seems to work. From my understanding, it should just put a still image on the dashboard. However, when configured, it doesn’t do that for me. In the Web UI it also doesn’t confirm that I’ve logged in at all, however after I press the confirm button it seems like it does something (it looks like it reloads the page). Has anyone had any luck with this? Thanks for all your help.
