How to iterate new templates fast?
You find multiple Energy yaml templates and you want to test them quickly but you notice your entity names are different.
Is there a way to iterate quickly through any yaml for anything on HA? (preferably without using a GPT).
That is bit vague. You are likely to get back a vague answer that will not help. Perhaps this would help you clarify the question a bit. How to help us help you - or How to ask a good question
Yeah, I thought it may not have an easy answer but probably someone has a better method than copy paste entities or a built in tool…
Well, I still have no idea what your question is, but maybe something in this link would help? The Home Assistant Cookbook - Index
Which part is not clear?
What you are actually trying to do, what a gtps is, among others Also why you didn’t bother to look at the links I gave you to help.
Depends what quickly really means:
The Studio Code Server App will flag/color Entity IDs that are not in your system. The drop down is driven by what’s already typed in, so as soon as you start typing in the correct entity ID, it will substitute a drop down of Entity IDs closer to what your target entity ID is and you can pick from the list.
It makes sure that the entity ID in the yaml is in your system.
Just substitute your entities into the provided templates and use the Settings → Developer Tools → Template editor to test them.
No environment vandalising LLMs required.
For template tests…
{% for entity_id in integration_entities('template') %}
  {# Perform Tests here #}
{% endfor %}
For any other tests on the entities themselves, just use the filters in the entity list to sort by template integration.
Thanks.
Where can this code be run?
The template editor.
