How to make a sequence of events
hi there,
i am not sure how to go about this,
I have created a switch for increasing tv up but one unit (via broadlink rm mini)
switch.samsung_vol_up
but i want to make it also go by multiples of 5 with a delay of 1 second in between.
need it to be triggered manually, no automation needed
thank you in advance …
If you can’t repeat the ir code 5 times in the switch config you will have to use an automation.
I tried something similar, but the IR signal was not consistent enough. Sometimes the volume went up as expected, but not all of the time.
I just added repeats in the IR code itself.
https://dimagoltsman.github.io/Random-Broadlink-RM-Code-Generator/#
