I want to track how much current has been over specified limit. Result in minutes.
Right now i have set binary sensor to turn on when over limit, then i have history_stats to show ON time, but it does not work like i was hoping.
I also set this history sensor to total_increasing but value is changing lower and higher.
As i would like sensor to only add time, not remove.
How should this be done?
If you have a base sensor that is ‘1’ when on and ‘0’ when off, then an integral helper of that sensor will be the lifetime amount of time that that sensor has been on.
Sounds like maybe that is what you want?
History stats can also do this but you need to set it up like the following:
- Need to make sure it’s a resetting interval, not a sliding window. So e.g. you can make a sensor of the amount of time you’re over the limit daily which resets to 0 each midnight.
- You need to force override the state_class with
customizeto total_increasing. - The lifetime ‘over limit’ count will only be visible as a long term statistic.
Sounds very similar to tracking how much time a force hot air furnace filter has been used.
Essentially I use the reimann sum integration and a utility meter. This example calculates in hours.
homeassistant:
customize:
sensor.um_furnace_filter_air_usage:
unit_of_measurement: hours
input_number:
um_furnace_filter_filter_life:
min: 0
max: 50000
step: 1
mode: box
input_button:
um_furnace_filter_filter_reset:
template:
- trigger:
- platform: state
entity_id: input_button.um_furnace_filter_filter_reset
- name: "um_furnace_filter_filter_replaced"
state: "{{ now().strftime('%Y-%m-%d %H:%M:%S') }} "
- trigger:
- platform: time_pattern
minutes: "/1"
- name: um_furnace_filter_per_hour
state: >-
{{ iif(states("sensor.ac_power")|int(0)>0 or states("sensor.furnace_power")|int(0),1,0) }}
attributes:
triggered_at: "{{ now().hour }}"
- sensor:
- name: um_furnace_filter_filter_life
unit_of_measurement: "%"
state: "{{ (((1.0 - ( states('sensor.um_furnace_filter_air_running')|float(0) / states('input_number.um_furnace_filter_filter_life')|float(0) )))*100.0)|round(1) }}"
- platform: integration
source: sensor.um_furnace_filter_per_hour
unit_time: h
method: left
round: 2
utility_meter:
um_furnace_filter_air_running:
source: sensor.um_furnace_filter_air_usage
recorder:
include:
entities:
- sensor.um_furnace_filter_air_running
- sensor.um_furnace_filter_air_usage
- sensor.um_furnace_filter_per_hour
- input_number.um_furnace_filter_filter_life
- input_button.um_furnace_filter_filter_reset
- sensor.um_furnace_filter_filter_life
- sensor.um_furnace_filter_filter_replaced
- binary_sensor.al_um_furnace_filter_filter_replace_alert
- alert.al_um_furnace_filter_filter_replace
- input_boolean.al_um_furnace_filter_filter_replace_alert_enable
input_boolean:
al_um_furnace_filter_filter_replace_alert_enable:
name: um_furnace_filter_filter_replace alert enable
binary_sensor:
sensors:
al_um_furnace_filter_filter_replace_alert:
value_template: '{{ (states("sensor.um_furnace_filter_filter_life")|float(1) <= 0.0) and is_state("input_boolean.al_um_furnace_filter_filter_replace_alert_enable", "on") }}'
alert:
al_um_furnace_filter_filter_replace:
message: 'ALERT {{state_attr("zone.home","friendly_name")}} um_furnace_filter_filter_replace '
done_message: 'Cleared {{state_attr("zone.home","friendly_name")}} um_furnace_filter_filter_replace '
entity_id: binary_sensor.al_um_furnace_filter_filter_replace_alert
state: "on"
repeat:
- 60
- 1440
can_acknowledge: true
skip_first: false
And then the automation to reset the utility meter when a button is pressed.
- id: reset um_furnace_filter filter
alias: reset um_furnace_filter filter
description: ""
mode: single
- platform: state
- service: utility_meter.calibrate
value: "0"
entity_id: sensor.um_furnace_filter_air_running
I have my history_stats sensor customized to total_increasing, now sensor looks like this
- platform: history_stats
name: "L2 yli 25A"
state: "on"
entity_id: binary_sensor.l2_yli_25a
unique_id: unique_l2_yli_25a
start: "{{ today_at() }}"
end: "{{ now() }}"
I had start {{ now() - timedelta(days=1) }} now changed to {{ today_at() }} lets see if that helps.
For that integral helper, it cant use binary_sensor, only sensor, so to use that i should create sensor instead of binary_sensor, that has states 1 and 0 ?
Yeah that should be better.
Yes, correct.
