nilux
August 19, 2022, 1:52pm
1
I have a template sensor that relies on other template sensors. They take an awful lot of time to update.
Should I just use update_interval: 5s
will force_update: true
solve the problem, or
can I do a lambda call on the Template Sensor to make it update when the sensor it depends on updates: on_update: then: - lambda: something
Any other option?
I’m assuming that updating sensors too frequently will slow down the device. Is it the case?
With this interval values (if they are changed) should be pushed every 5 seconds to HA.
No as it will just send the values with the same interval but also when they are not changed (typically a bad idea for most cases)
There is a component.update
nilux:
Any other option?
Many
No
nilux
August 19, 2022, 2:21pm
3
Thanks, the component_update
action is just what I need. The documentation is really good, but sometimes it’s hard to find the thing you don’t know you’re looking for.
nilux
August 30, 2022, 12:20pm
6
A note to anyone using component.update
; beware of calling this on a sensor from multiple places simultaneously. For instance something like this might jam the device:
- id: sensor1
on_value:
then:
component.update: sensor2
component.update: sensor3
- id: sensor2
lambda: |>
return id(sensor1).state;
on_value:
then:
