How to migrate bhyve virtualised HAOS from FreeBSD host to Proxmox host
This took me several hours to figure out so just dropping my notes here to hopefully help someone else.
This was how I did:
  • Assumptions: ZFS as filesystem on both FreeBSD host and Proxmox host
  • Followed this guide for how to create HAOS vm: Installing Home Assistant OS using Proxmox 8
  • From FreeBSD bhyve host: zfs send zroot/ROOT/default/homeassi/dsk1.vhd | ssh [email protected] 'zfs receive rpool/data/homeassistant-dsk1.vhd'
  • Convert and import disk image:
 qemu-img convert -f raw -O qcow2 /dev/zvol/rpool/data/homeassistant-dsk1.vhd /rpool/data/homeassistant-dsk1.qcow2
# Replace <id> with id of vm created via script
qm disk import <id> /rpool/data/homeassistant-dsk1.qcow2 local-zfs
  • Remove the harddrive that got created when creating HAOS vm via script – then add&attach the imported harddrive image.
