here is an extract from the yaml
- entity: sensor.red_wks
states:
-id: 4
entity_index: 4
exposure: 80
ypos: 5
styles:
- font-size: 1em;
I tried all that (x4) but it doesn’t work:
- id: 4
entity_index: 4
xpos: 80
ypos: 5
styles:
- font-size: 1em;
- font-weight: normal;
- fill: |
let entity = { state: “On” };
let value = entity.sensor.ups_wks;
console.log(value);
if (value == On) return “#ffa500”; // Orange
else if (value < 8000) return “#ffff00”; // jaune
else return “#00ff00”; // vert
- id: 4
entity_index: 4
xpos: 80
ypos: 5
styles:
- font-size: 1em;
- color: |
{% if
is_state('binary_sensor.red_wks', 'On') %}
green
{% else %}
red
{% endif %}
- id: 4
entity_index: 4
xpos: 80
ypos: 5
styles:
- font-size: 1em;
text_template: |
{% if is_state('sensor.red_wks', 'On') %}
<span style="color: green;">On</span>
{% else %}
<span style="color: red;">Off</span>
{% endif %}
show_state: false
show_unit: false
- id: 4
entity_index: 4
xpos: 80
ypos: 5
styles:
- font-size: 1em;
card_mod:
style: |
:host {
--horseshoe-color: {% if is_state('sensor.red_wks', 'on') %} green {% else %} red {% endif %};
stevemann
(Stephen Mann (YAML-challenged))
2
Please read: How to help us help you - or How to ask a good question - Configuration - Home Assistant Community
Post your YAML in code tags. The forum editor screws up the formatting of YAML to make it unreadable.
Continuing the discussion from How to modify the yaml so that the display of the state id displayed -> On is green and red if -> Off:
type: custom:flex-horseshoe-card
entities:
- entity: sensor.temperature_chauffe_eau_temperature
decimals: 1
icon: mdi:temperature-celsius
area: Chauffe eau
- entity: sensor.pzem1_pzem_004t_v3_power
decimals: 0
- entity: sensor.test_outside_light_level
decimals: 0
- entity: sensor.ups_wks
styles: null
show:
scale_tickmarks: true
layout:
hlines:
- id: 0
xpos: 50
ypos: 38
length: 40
styles:
- stroke: var(–primary-text-color);
- stroke-width: 5;
- opacity: 0.9;
- stroke-linecap: round;
color: “#fcfc74”
vlines:
- id: 0
xpos: 50
ypos: 58
length: 20
styles:
- opacity: 0.5;
- stroke-width: 2;
states:
- id: 0
entity_index: 0
xpos: 50
ypos: 30
styles:
- font-size: 3em;
- opacity: 0.9;
- id: 1
entity_index: 1
xpos: 46
ypos: 54
styles:
- font-size: 1.5em;
- text-anchor: end;
- id: 2
entity_index: 2
xpos: 54
ypos: 54
styles:
- font-size: 1.5em;
- text-anchor: start;
- id: 3
entity_index: 3
xpos: 1
ypos: 5
styles:
- font-size: 1em;
- id: 4
entity_index: 4
xpos: 80
ypos: 5
styles:
- font-size: 1em;
- color: |
{% if
is_state(‘binary_sensor.red_wks’, ‘On’) %}
green
{% else %}
red
{% endif %}
names:
- id: 0
entity_index: 1
xpos: 46
ypos: 62
styles:
- font-size: 0.8em;
- text-anchor: end;
- opacity: 0.7;
- id: 1
entity_index: 2
xpos: 54
ypos: 62
styles:
- font-size: 0.8em;
- opacity: 0.7;
- id: 2
entity_index: 3
xpos: 0
ypos: 10
styles:
- font-size: 0.8em;
- opacity: 0.7;
- id: 3
entity_index: 4
xpos: 76
ypos: 10
styles:
- font-size: 0.8em;
- opacity: 0.7;
areas:
- id: 0
entity_index: 0
xpos: 50
ypos: 100
styles:
- font-size: 1.2em;
- opacity: 1.5;
horseshoe_state:
color: “#96f261”
horseshoe_scale:
min: null
max: 65
color: “#96f261”
width: 3
color_stops:
“35”: “#96f261”
“40”: “#FFE9B9”
“45”: “#FFDA8A”
“50”: “#FFBF37”
“55”: “#FFB414”
“58”: “#FFAD12”
“37.5”: “#FF9C0B”
“42.5”: “#FFE8C06”
“47.5”: “#FFCB5B”
“52.5”: “#ffb414”
petro
(Petro)
4
Please format your code, you still haven’t formatted it properly.
Suggest to rename the thread - add a “horseshoe” word.
