What I did was
1. Installed iSMC
2. Wrote a flattening wrapper script to collapse the nested structure into flat Category_SensorName: value pairs (e.g. Temperature_CPU_Diode_Virtual_1), pulling quantity (clean float) over the string value.
3. Set up SSH auth
4. Wired it into HA config:
New
command_line: !include command_line.yamlinconfiguration.yaml, with acommand_linesensor running the SSH call every 60s, exposing the flattened values asjson_attributes. -
Added five derived
templatesensors in the existingtemplates.yaml(CPU temp, GPU temp, fan speed, CPU power, total power), each pulling viastate_attr()off the raw sensor.
Open to suggestions/alternatives.
