How to pass the state_value of an entity as a parameter into a Custom componet class
I have this situation
I would like to pass several H.A. entities value to the class of my custom component library into the YAML code
let’say the entity is given by a helper
her my C code
---C code---
my personal .h file
class cESPCustomDevice : public PollingComponent, public Sensor {
  public:
    float param1, param2, param3;
    cESPCustomDevice(float p1, float p2, float p3) : PollingComponent(100) { //costructor
      param1 = p1;
      param2 = p2;
      param3 = p3;
	Sensor *MySensor = new Sensor();
	MySensor->publish_state(val);
so once defined in H.A. a helper “input_number.param1”
I have this YAML
---YAML code---
#definition of a "local" entity 'par1' equal to the global H.A. entity input_number.param1
- platform: homeassistant
  entity_id: input_number.param1
- ...Param_2
- ...Param_3
#using the local entity id(par1).stateto pass at the my class "cESPCustomDevice" the value of
# global entity input_number.param1 (H.A. helper)
- platform: custom
  lambda: |-
    auto esp_customcomponent = new cESPCustomDevice(id(par1).state, ... , ...);
    App.register_component(esp_customcomponent);
    return {esp_customcomponent->MySensor};
This trick WORKS fine but my question is:
There is a EASIER and DIRECT solution to pass the entity value “input_number.param1” in the YAML file instead to define a local entity “par1” and passing it ???
I guess this is a bit redudant and there shoul be an simpler way.
I tried with
- platform: custom
  lambda: |-
    auto esp_customcomponent = new cESPCustomDevice(id(input_number.param1).state, ... , ...);
and also
  auto esp_customcomponent = new cESPCustomDevice(id(input_number.param1).currentstate, ... , ...);
But it doensn’t work
Somebody have a suggenstion?
I suggest that this is the way to do it.
Checking better, I was wrong it doens’t work @nickrout
If I print the directly into the C code id(par1).state it work th lgo is pronted correctly
Unfortunatly this is a hardcoded solutions, not flexible.
I would like to pass the parameter to the class instance delaration in th yaml
 auto esp_customcomponent = new cESPCustomDevice(id(par1).state, 123 , 345.);
If I pass a constant parameter (such 123 or 345) when I define the class,
the value is logged correctly but it doesn’t recognize the value of instance par1
In this case the LOG stamp indicates me value “nan”.
Do I miss something?
Hello, nobody has ever faced up this issue?
