I am getting started with Home Assistant and I have Rhasspy Voice activatedintents working with Home assistant.
I am able to successfully send voice intents from Rhasspy to HA. I can also call a rest_command to POST a message via TTS to Rhasspy.
What I cannot seem to do these together in tandem. For instance:
Send via Rhasspy (“What is my External IP”) --> Invoke a API to find the External IP --> POST the response of the API call back to Rhasspy.
If anyone has a basic working example of this bi-directional payload “loop” it would be great. I am aware of REST Sensors but cannot seem to find a working example of this.
Thanks. I was able to use the following combination:
Rhasspy Intent --> HA Intent --> REST_COMMAND (HA) action --> Invoke TTS API
I can also pass variables via a sensor + Automation.
Ideally, i would want a full flow such as follows:
Voice Intent (with a variable passed) --> Invoke a REST “Sensor” using variable (POST) --> Obtain a response (GET) from the reply Payload --> Respond back to Rhasspy via TTS with the payload.
It seems HA allows for this all to work but was hoping for a working example example.
