How to persist EspHome "Template Binary Sensor" state on reboot?
Hi Guys,
I’d like to persist my Template binary Sensor state on a reboot. I created this config with global variables which are soupposed to survive a reboot but for some reason they always default to ‘on’ after a reboot.
Could soneome please have a look at it? Thank you! :slight_smile:
#Device Specific Config
esp8266:
  board: esp01_1m
  restore_from_flash: true
esphome:
  build_path: "./.build/${device_name}/"
  on_boot:
    priority: 800
    then:
      - lambda: |-
          id(template_sensor_1).publish_state(template_sensor_1_global);
          id(template_sensor_2).publish_state(template_sensor_2_global);
          id(template_sensor_3).publish_state(template_sensor_3_global);
          id(template_sensor_4).publish_state(template_sensor_4_global);
          id(template_sensor_5).publish_state(template_sensor_5_global);
globals:
  - id: template_sensor_1_global
    type:  bool
    restore_value: true
  - id: template_sensor_2_global
    type:  bool
    restore_value: true
  - id: template_sensor_3_global
    type:  bool
    restore_value: true
  - id: template_sensor_4_global
    type:  bool
    restore_value: true
  - id: template_sensor_5_global
    type:  bool
    restore_value: true
switch:
  - platform: gpio
    pin: GPIO4
    restore_mode: ALWAYS_OFF
    internal: true
  - platform: restart
binary_sensor:
  - platform: gpio
    pin: GPIO5
    internal: true
    on_multi_click:
      - timing:
        - ON for at most 0.5s
        - OFF for at least 0.5s
        then:
          - logger.log: "Single Clicked"
          - lambda: |-
              if (id(template_sensor_1).state) {
              id(template_sensor_1).publish_state(false);
              id(template_sensor_1_global) = false;
              } else {
              id(template_sensor_1).publish_state(true);
              id(template_sensor_1_global) = true;
              ESP_LOGD("TAG", "Global value is: %d", id(template_sensor_1_global));
      - timing:
          - OFF for at most 0.5s
        then:
          - logger.log: "Double Clicked"
          - lambda: |-
              if (id(template_sensor_2).state) {
              id(template_sensor_2).publish_state(false);
              } else {
              id(template_sensor_2).publish_state(true);
      - timing:
        then:
          - logger.log: "Tripple Clicked"
          - lambda: |-
              if (id(template_sensor_4).state) {
              id(template_sensor_4).publish_state(false);
              } else {
              id(template_sensor_4).publish_state(true);
      - timing:
        then:
          - logger.log: "Quadruple Clicked"
          - lambda: |-
              if (id(template_sensor_5).state) {
              id(template_sensor_5).publish_state(false);
              } else {
              id(template_sensor_5).publish_state(true);
      - timing:
          - ON for at least 0.8s
          #- OFF for at least 0.5s
        then:
          - logger.log: "Long Clicked"
          - lambda: |-
              if (id(template_sensor_3).state) {
              id(template_sensor_3).publish_state(false);
              } else {
              id(template_sensor_3).publish_state(true);
