I have a Halloween .mp3 file I’d like to play on my one Sonos speaker on Halloween night. Can someone tell me how to:
- Copy an .mp3 file to the Home Assistant Green?
- How to play that file on a Sonos speaker?
-Thanks
-Thanks
Hello Bernie
When I want to store media, I want to be able to easily not back it up, so I do this. The backup integration has a specific button to exclude the media folder.
For me in configuration.yaml
homeassistant:
media_dirs:
local: /media
Then the /media path becomes part of /local .
And put the mp3 in a folder in HA under
/media/mp3
(The media folder already exists, you would want to add a sub folder to that, or at least I did, to keep your OCD happy.)
When I want to use an MP3, the path is
media-source://media_source/local/mp3/Ships_Bell_4.mp3
Adjust as you desire, but that is a basic version of mine. Works for all media.
Longer version in here: HA Config
Thanks. How do you copy the file to the /media folder? Is there file manager? Or samba maybe?
I use a samba add-on, but there are different ways. Try a search for something that fits your use case.
Put this in any search engine:
site:home-assistant.io add files to media folder
Thanks again, found it.
If this suggestion solves your problem, please consider clicking the solution button to close the thread.
Done.
Thanks again.
