How to properly trigger an automation with Aqara Wall Switch V1 via Matter?
HA Docs - Event Integration
Sharing screenshots of the UI isn't "quick"... it's slow, cumbersome, and error-prone. Nearly every exchange requires both you and us to duplicate the effort of making the edits in the UI, taking one or more screenshots, then uploading them. We share YAML because it is editable, fast, complete, and portable... in most cases it can be pasted directly into the UI editor.
For some "advanced" options you may need to use the Automation or Script editor's "Edit in YAML" option... then, once you save it, you can easily switch back to the Visual editor.
