I’m trying to put a “logbook.log” Action node inside a sub-flow, and want to pass the entity_id and message in through sub-flow environment variables - but I can’t work-out what format to use inside the Jsonata data expression.
An existing logbook write action node might have this in the Data field:
{“name”:“HWS Relay”,“entity_id”:“switch.hws_logbook_entries”,“message”:“Turned On”}
I have 2 Sub-flow environment variables:
LOG_ENTITY
LOG_MESSAGE
How would I change the Jsonata to reference the environment variables instead of the static text?
(I am strictly a “monkey-see, monkey-do” when it comes to Jsonata, and have exhausted the possibilities I can think of for the correct formatting.)
