Hi, I’m looking a way to reload the yaml integration “SmartIR”
Reload Config entry doesn’t work, neither do Reload All
I’ve also tried to find the config entry id of the integration without success
My use case:
Sometmes SmartIR Fails to load during HA Boot, (I’ve seen with tuya integration sometimes too) and the integration states shows as “Not Loaded”. A simple reload integration works perfectly, but i can’t find a way to reload the SmartIR integration.
(I know restarting core will solve it, but I’m trying to make HA sort itself out)
This is probably something you need to take up with the 3rd party developer via their issues page on github as a Home Assistant restart is the only way.
