How to remove a Z-Wave device that is missing from the network?
Hi from France
I would like to remove a device that I had added via Z-Wave. This device is no longer on the Z-Wave network, so it is considered “dead.”
I tried going through Settings > Devices & Services > Z-Wave and selecting the device I want to remove: clicking the 3 dots to the right of “Configure,” selecting “Remove,” and then confirming the removal in the pop-up window… but it’s still there!
I also tried going through Z-Wave JS > [relevant device] > Advanced > Failed node > Remove… but it’s still there!
Can you help me?
Best regards.
Configuration:
version core-2026.8.3
installation_type Home Assistant OS
dev false
hassio true
docker true
container_arch amd64
user root
virtualenv false
python_version 3.14.6
os_name Linux
os_version 6.18.39-haos
arch x86_64
timezone Europe/Paris
config_dir /config
I don’t know about ZJS specifically, but have had issues with past exclusions on coordinators with old firmware.
It was a while ago, but openHAB and early HA didn’t exclude and the coordinator stopped the Z-Wave network for a 120S timeout a few times
After updating the coordinator firmware, all worked - including the exclude.
Basically, HA is only part of the story - the coordinator needs to do the work. A firmware update might be worth a try (RaZberry - issues, Aeon v3+ - issues, now ZWA-2 - AOK).
Is there a “Force Remove” option?
