How to remove duplicate Z Wave devices?
My Shelly Wave Roller Shutter just received an update (12.23 to 14.2). For the update to work I had to factory reset the devices. After doing so a duplicate entry appeared in the Home Assistant Z Wave integration. One with the old an one with the new firmware. The device with the old firmware is in a limbo state, has no entities and it says:
This device has been provisioned but is not yet included in the network.
I reloaded the z wave integration and restarted home assistant but nothing worked. I can’t delete the devices either. Any idea how to remove it?
I had a rather similar experience a few days ago caused by the (initially) faulty replacement of a Zwave device. I found that it had been caused by HA trying to re-interview the duplicate, but removed, devices. At that time I was unable to remove those devices but when the re-interview process ended I was able to remove them.
In short, try to remove these tomorrow morning.
This does not happen if you name device in zwavejsui.
When replace or remove/readd device if you use same name HA will recognize as same device. Reload of integration may be needed but usually not.
I’m don’t think naming is available for zwavejs if you use that but transition to zwavejsui is possible.
My issue was different… For one reason or the other, the including of the new device failed several times when using the HA App on my Iphone but it created ā€˜phantom’ devices in HA. I finally included the device succesfully after power cycling my Yellow Box. At first I was at first unable to remove these ā€˜phantom’ devices but I did after the re-interview process ended.
I still can’t remove it. Under Settings → Devices the delete action for zwave devices is greyed out. I can only deactivate the device. Under Zwave JS it shows up only once, which is correct.
Did you try it after power cycling the unit that contains HA ?
Aaargh with previous wave shutter update they changed polarity of all switches. Now it’s factory reset :expressionless:. Worst of all venetian blinds don’t work in Home Assistant (no tilt on entity). Shelly updates are really scary.
I restarted the entire maschine, did not work.
I think the issue is that Shelly renamed the product code in the firmware update from QLSH-001P10 to QLSH-001P10EU. The not working device is still showing the old product code. I still haven’t figured out how to delete it.
When I reloaded zwave integration duplicates disappeared, but after I re-interviewed 1 device it appeared again as duplicate.
There is a fix that seems to be related:
Maybe it helps.
Thank you, I’ll wait for the next HA Core release and see what happens
Link above is incorrect. This is the proper one (to PR):
I upgraded to 2026.1.1 and venetian blinds are supported again.
Now I just have to configure and calibrate 9 blinds, and retest 18 automations and it should be ok
Face the same issue after FW update of Shelly Wave Shutter. Any updates to solve this issue?
Hey, same issue here just like OP and @martin281 , updated my Shelly Shutters and now I have duplicates in HA devices (the one with the updated FW is working, the ā€œoldā€ one isn’t). How to handle this?
Did you find any solution?
Unfortunately not… I ended up removing the devices and had really trouble to get them back into my network. I’ve kind of documented my journey here:
https://community.shelly.cloud/topic/13171-firmware-1420-and-ha-zwave-js-issues/#comment-56003
I do not recommend.
If you have two z-wave controllers, best way is to update firmware with your debug controller and then add the device to your home network. Or wait until this issue fixes itself maybe with a z-wave-js update.
Seems that I found a way to get rid of the duplicate Shelly Qubino Wave Shutter after updating to the 14.2.0
  1. Name the device in the Z-Wave integration and Z-Wave JS Server (version 1.1.0) identical
  2. Performe the update to 14.2.0
  3. Douplicate devices appear → rename the old version ghost device (e.g. ā€œ_defectā€)
  4. Deactivate the ghost
  5. Exchange the device in all automation, scripts, etc. with the new device
  6. Make sure there are no devices in the Z-Wave JS Server provision list
  7. Update the Z-Wave integration
==> duplicate devices (deactivated) are gone
Also works if more than one devices have been handled according step 1 to 6.
