How to remove orphaned calendars?
Short version - how do I delete unwanted calendars from the local calendar store?
Long version - due to attempts to work around this bug ( Todoist integration custom projects not working · Issue #87343 · home-assistant/core (github.com)) earlier this year, I’m left with several duplicate calendars in my local calendar store. I want to remove those to clean things up.
I’ve tried removing the Todoist integration, rebooting, and then re-adding the integration - no luck.
I hope this does what you want:
Go to: Settings-Integrations then click/select the -Local Calendar- integration. Now, find the calendar you want to delete under -Integration entries- and click on the hamburger menu (three dots) to the right of the menu name and click on -Delete-, and finally confirm the action in the pop up menu.
Thanks, it worked for me.
For folks that might be slower than I… Settings → Devices and Services (the Integrations are there).
Is there a linguist, or ui-consultant, in the house? :wink:
MrGrey.
