How to remove standalone image "oznu/homebridge" from HA?
Hello everyone,
I am pretty new to Home Assistant so thank you for your patience in advance
I recently install Home Assistant OS using the vmdk file on ESXi 7.0. Everything works well
Then, I installed Portainer and Homebridge. However, in the last updates, HA has removed the support for Portainer.
So I uninstalled the Portainer without realizng first that I need to remove/delete the homebridge instance
Now, everything still works OK except that the Supervisor mode keeps saying that there’s unsupported images:
“WARNING (MainThread) [supervisor.resolution.evaluations.base] Found unsupported images: {‘oznu/homebridge’} (more-info: Unsupported software - Home Assistant)”
Using SSH & Terminal to access the HA OS, but it does not support “docker ps -all” (docker bash not found)
Is there a way to complete clean up this standalone image without reinstalling the whole HA OS?
Thank you again for you helps
Cheers
If you want to run docker commands within ssh & web terminal, turn protection mode off in ssh & web terminal.
Where is portainer being removed documented?
Found it! I can understand why, given how locked down HA is becoming.
Anyway, you have your answer :slight_smile:
Hi Nickrout,
My SSH & Terminal only has the following options
Start on boot
Watchdog
Auto update
Show in sidebar
It does not come with protection mode…
Any ideas?
Thanks again
Attention!
There are 2 slightly different named add-ons: I think you use “Terminal & SSH” that has less functions.
SSH & Web Terminal is the needed one.
It should look like this:
I found SSH & Web Terminal, installed it but when I run it, it throws “502 Bad gateway” error…
Something is wrong here…
Any helps
FWIW, I have cloned the portainer addon here:
You’re the best
Thank you so much Koying! You are a lifesaver!
I too did as jamesngob and deleted Portainer without stopping homebridge due to nag messages my instance was not supported. :frowning:
If you’re seeing 502 Bad Gateway, make sure you have the protection mode turned off! This worked for me.
