Hey guys just trying to give a custom name to a sensor in a manual card. I havent really played much with manual/custom cards before
Any ideas. I dont really want to change the actual name as it is used for other purposes
Just to clarify, you don’t want to change the friendly name for the entity so that it shows as “Forecast” globally correct?
If so, I don’t use this integration but with others that are setup in a similar way you would do the following.
- sensor.avalon_humidity
- sensor.avalon_temp
- entity: sensor.lara_short_text_0
Thanks for the reply mate. I dont want to change the name globally just for this specific card. As you can see in the pic the name feature isnt working
I tried a few different things but couldn’t get it working.
Your options:
