I have a todo list, and sometimes people in the family accidentally add a trailing empty space on an item, like this:
This is causing issues with finding and removing duplicates in the list, so I want to remove this empty space with an automation, using the todo.update_item
to rename it.
This is my attempt:
alias: Remove duplicate items
description: ""
triggers: []
conditions: []
actions:
- action: todo.get_items
entity_id: todo.test_list
status:
- completed
response_variable: completed_items
- variables:
item_to_rename: "Pears "
- action: todo.update_item
item: "{{ item_to_rename }}"
rename: "Pears"
mode: single
Unfortunately it seems that when using "{{ item_to_rename }}"
then the trailing empty space is stripped, and the update_item
action does not find the item in the list. How can I remove the empty space in the list item?
I have tried using the following:
"{{ item_to_rename | to_json }}"
"{{ item_to_rename | regex_replace('\s+$', ' ') }}"
"{{ item_to_rename + '\u00A0' }}"
"{{ item_to_rename | replace(' ', '\u00A0')}}"
"{{ item_to_rename | escape }}"
But cannot get any of them to work.
