How to retrieve the zone of a sensor in a script?
Does anyone know if it’s possible to retrieve the zone where a sensor is in a script or a template ?
I added different zone in my house, like kitchen, room children 1, bathroom, … and to this differents zones the devices created by mqtt integration.
I want to do a resume of all temperature sensors I have in a script and send it in a notification. For example I want my script return :
Resume Temp
  • Room children 1 : 19.8°C - 45.3%
  • Kitchen : 19.8°C - 45.3%
  • Bathroom : 19.8°C - 45.3%
I found how iterate over all sensors and keep only those ending with _temperature for example. I can get the state value. But I’m unable to access the zone name to display it in my message.
I tried in a python script :
for e in hass.states.entity_ids():
    if e.startswith("sensor.temp") and e.endswith("_temperature") :
        logger.warn("Entity : %s", e)
        logger.warn("State : %s", hass.states.get(e))
But there is no attribute that refer the device where the sensors is or the area_id.
The goal is, when I add a new temperature sensor, I have nothing to do except add it in an area and my message let appear the new zone temperature. No template to modify or something else.
Thank’s for help!
“Area”.
Zones are for geolocation.
Ah ok , thanks, but I don’t see anything about area in sensors attributes. Can I retrieve area from anywhere ? Get all sensors in an area ? Or get Area from a sensor ?
The answer to all three questions is no. Currently, area is inaccessible to templates. All you can currently do with an area is to use it as the target for a service call (for example, turn on all lights in a given area).
Ok thank you for the answer :+1:! May be in a futur version :sweat_smile:
You’re welcome!
If you want to organize entities into some form of “collection” that can be referenced in a template, I suggest you consider using a Group.
Yes, group was my first intention but the inconvenience is to add manually each time I add a new temperature sensors. Ok, it’s not every day :laughing:
I was using Jeeedom before and I try to do the same things I had on this platform. Home assistant is quite hard for a beginner :sweat_smile:
Thank’s again for help.
It’s possible to have dynamically-created groups. For example, the following automation is triggered on startup and whenever the group.reload service is called. It selects all sensors whose device_class is temperature and adds them to a group called group.temperature_sensors.
- alias: 'Create group'
  description: 'Dynamically create group on startup and reload'
  - platform: homeassistant
    event: start
  - platform: event
    event_type: 'call_service'
    event_data:
      domain: 'group'
      service: 'reload'
  - service: group.set
      object_id: temperature_sensors
      entities: >
        {{ states.sensor
           | selectattr('attributes.device_class', 'eq', 'temperature')
           | map(attribute='entity_id') | list }}
Sorry for reviving this topic.
You can get the area of a sensor using these:
{{ area_id('binary_sensor.esp32_ble_tracker_test_ibeacon') }}
Use
area_name
