Hello,I am new to Home Assistant and need help running the voice assistant pipeline I created from an automation.So far, I have the following automation set up, but when I run it, I receive an error indicating that the domain is not provided for the assist service. I noticed that all services have their domains configured, corresponding to specific integrations within Home Assistant. However, the voice assistant documentation does not provide relevant information (Voice Assistant - Home Assistant).I attempted to use the assist_pipeline
integration (Assist pipeline - Home Assistant), but I couldn’t get it to work from automation either.The only successful method I’ve found is to run it from the dashboard using the following tap_action
tap_action:
action: assist
start_listening: true
pipeline_id: preferred
However, I need to be able to trigger my voice assistant from automation, and I’m currently stuck. I’ve searched for similar topics in this forum but haven’t found anything relevant. Any tips on how to resolve this issue would be greatly appreciated.Thank you!
Automation I’m Struggling With
alias: “Run My Voice Assistant Pipeline”
description: “Trigger my voice assistant pipeline when the helper button is activated.”
- platform: state
entity_id: input_boolean.my_voice_assistant_pipeline
to: ‘on’
action: - service: assist # Update this line with the correct service name
