The goal: Create a “Extended Away” button that when switched on will save the state of a set of entities on persistent storage, then will restore these when the button is switched off.
The approach:
1 - Use a trigger sensor to save the data - Done (may require changes)
2 - Build a dynamic scene and apply it using the scene.apply
service - Having trouble.
This is the Trigger Sensor. The entities
list will be a somewhat longer though. Notice there are different types of entities that the script takes into account (and more can be supported):
- trigger:
- platform: event
event_type: away_mode_save_state
- unique_id: d29aa7e2-62e1-4836-b94c-657666c9c4b8
state: data
attributes:
data: >
{% set ns = namespace(
entities=[
'climate.living_room',
'switch.front_door_light',
items=[],
{% for entity in ns.entities %}
{% set type = entity.split('.')[0] %}
{% if type == 'climate' %}
{% set attrs = { 'temperature': state_attr(entity, 'temperature') } %}
{% elif type == 'switch' %}
{% set attrs = {} %}
{% endif %}
{% set ns.items = ns.items + [ dict({ 'entity': entity, 'state': states(entity) }, **attrs) ] %}
{% endfor %}
{{ns.items }}
This works well. The entity will look like this:
Now, I’m trying to restore the state using an automation that uses scene.apply
, but I can’t make it work.
- id: "away_mode_restore_state_automation"
alias: Away Mode Restore State
description: Restore state saved when enabling Away Mode
- platform: event
event_type: away_mode_restore_state
- service: scene.apply
entities: >
{% for entry in state_attr('sensor.away_mode_saved_state', 'data') %}
{% set type = entry.entity.split('.')[0] %}
{{ entry.entity }}:
state: {{ entry.state }}
temperature: {{ entry.temperature }}
{% endif %}
{% endfor %}
mode: single
When triggered, it fails with:
expected dict for dictionary value @ data['entities']
What am I missing here?
I also considered using a python script for the restore part, but I’m still a beginner on the matter. Let me know if that sounds like a better choice.
I also considered using a dictionary instead of an array for items
(keys being the entity
and the values being all the rest of the state/attributes). But I’m having a bit of trouble achieving it, as the keys are dynamic (entry.entity
). Let me know if anyone knows how to do it as well.
I also considered using scene.create
, but that’s won’t survive reboots. Maybe I could create the scene, and use it to save to the trigger entity above. But seems very convoluted.
Thanks a lot for your help!
