Is there any way to see what the raw request and response is when you interact with the Assistant? Basically I wanna see the exact system prompt (not just what I typed in) + metadata (entities, etc) that is sent to the LLM (OpenAI or Gemini), and the exact raw response.
I’m trying to troubleshoot an issue where the Assistant sometimes refuses to call scripts that perform camera analysis using LLM Vision, so it just makes stuff up.
Hi Nathan - so how would I go about extracting some of the information in the debug log? I’m particularly interested in accessing the response type so that I can TTS a custom response to a media player other than the voice assistant that received the command. If that makes sense…
At the moment my voice agents are silent. I am using custom sentences and intents only, and the intents direct TTS to the local Sonos speakers.
When a command is not understood, this means nothing happens. To start with at least I would like to be able to access the response type and if it is “error”, use it as a trigger to send a TTS “Sorry, didn’t quite get that” to the Sonos.
So it would be something like…
Voice agent wakes
Spoken command sent to speech recognition engine
Intent recognised - execute command
- TTS "blah blah blah" to Sonos
Intent not recognised - TTS "Sorry, didn't quite get that" to Sonos
There seem to be all sorts of usable hooks in the conversation process, but I don’t know how to get at them.
Neither one of these provides the raw LLM request, I’m basically looking for the HTTP payload that was sent to and received from the LLM API (OpenAI or Gemini). I’m looking to see what the exact system prompt is, since “Instructions” is just a part of it.
Did you ever figure this out? I’m looking for the exact same thing.
I want to see the entire request that Gemini receives. Mainly because I want to see how the exposed entities are structured in the request so that I understand what the LLM has to work with.
