Hi all,
I need help with a script.
I want a script to change the brightness of the lights in a particular area (defined by “room_id”) but ONLY those in that room that are currently on. I can’t get it to work.
It first should calculate the average brightness of the all the lights that are ON, and then it moves up or down depending on an external helper. I want it to do it every 1s, with transitions of 1s, until a signal of “stop” is received.
This part works, however, the script is unable to work only on the lights that are currently ON. It always turns ALL the lights on, also those that were OFF.
How can I select only the lights that are ON and work on them only?
Thanks.
alias: Brightness Adjust Smart Retry v1 (works only on 1st instance of loop)
description: >
Continuously adjusts brightness up or down once per second using transitions.
All lights are synchronized to the same brightness level. Uses fixed limits
1–255. Ignores lights that are OFF. Works with room_id.
mode: restart
fields:
entity_ids:
description: Lights to adjust (optional when using room_id)
required: false
selector:
entity:
domain: light
multiple: true
room_id:
description: Optional area whose lights will be controlled
required: false
selector:
area: {}
command:
description: Start or stop loop
required: true
selector:
select:
options:
- start
- stop
brightness_step:
description: Amount to change brightness per step
selector:
number:
min: 1
max: 100
step: 1
default: 30
variables:
lights_from_entities: "{{ entity_ids if entity_ids is defined else [] }}"
lights_from_area: |
{% if room_id is defined %}
{% set area_lights = area_entities(room_id) | select('match','^light\.') | list %}
{% set on_lights = expand(area_lights)
| selectattr('state','eq','on')
| map(attribute='entity_id')
| list %}
{{ on_lights }}
{% else %}
{% endif %}
all_lights_raw: "{{ (lights_from_entities + lights_from_area) | unique | list }}"
lights: |
{{ expand(all_lights_raw)
| list }}
step_size: "{{ brightness_step | int }}"
direction: "{{ states('input_text.brightness_direction') | lower }}"
max_limit: 255
min_limit: 1
sequence:
- if:
- condition: template
value_template: "{{ command == 'stop' }}"
then:
- variables:
current_dir: "{{ states('input_text.brightness_direction') }}"
- action: input_text.set_value
entity_id: input_text.brightness_direction
value: |
{% if current_dir == 'up' %}
down
{% else %}
up
{% endif %}
- stop: Stopped brightness loop.
- repeat:
while:
value_template: "{{ command == 'start' }}"
sequence:
- variables:
brightness_values: |
{{ expand(lights)
| map(attribute='attributes.brightness')
| select('defined')
| list }}
avg_brightness: >
{{ (brightness_values | sum / (brightness_values | length)) | int
- choose:
- conditions:
value_template: "{{ avg_brightness >= max_limit }}"
sequence:
value: down
- conditions:
value_template: "{{ avg_brightness <= min_limit }}"
sequence:
value: up
- variables:
direction: "{{ states('input_text.brightness_direction') }}"
new_brightness: |
{% if direction == 'up' %}
{{ [255, avg_brightness + step_size] | min }}
{% else %}
{{ [1, avg_brightness - step_size] | max }}
{% endif %}
- repeat:
for_each: "{{ lights }}"
sequence:
- action: light.turn_on
entity_id: "{{ repeat.item }}"
brightness: "{{ new_brightness }}"
transition: 1
- delay:
seconds: 1
