How to select lowest temperature only from rooms with HVAC off?
Hi everyone, i have 5 temperature sensors related to 5 heat pumps.
I set an automation with which i control them based on solar production and power consumption but, at least by now for how the automation works, i can get into a loop in which the coldest room is so cold that even after i turn the heat pump on is still the coldest of the house.
By now i check every 10 minutes what’s the current power consumption and which room is the coldest… would it be possible to check which room with HVAC off is the coldest one and start that instead?
In this way i could also do the same in the opposite way: i could turn off the warmest one when i have too much power consumption to try reduce it
Post automation please
