How to select measurements
for influxdb explore?Overview shows all sensors.
The problem: screenshot lower right
no help, wrong question?
# Loads default set of integrations. Do not remove.
default_config:
# Text to speech
tts:
  - platform: google_translate
script: !include scripts.yaml
scene: !include scenes.yaml
lovelace:
  mode: yaml
#Heizung
modbus:
  - name: SYSTAComfort2
    host: 192.168.178.20
    type: tcp
    port: 502
    sensors:
      - name: "Aussentemp TA"
        scan_interval: 100
        slave: 1
        input_type: input
        unique_id: sensor.aussentemp_ta_2
        scale: 0.1
        unit_of_measurement: °C
        address: 0
        data_type: int16
      - name: "Vorlauftemp HK1 TV"
        scan_interval: 100
        slave: 1
        input_type: input
        scale: 0.1
        address: 1
        data_type: int16
      - name: "Rücklauftemp HK1 TR"
        scan_interval: 100
        slave: 1
        input_type: input
        scale: 0.1
        address: 2
        data_type: int16
      - name: "Warmwassertemp Oben TWO"
        scan_interval: 100
        slave: 1
        input_type: input
        scale: 0.1
        address: 3
        data_type: int16
      - name: "Vorlauftemp Kessel FATV"
        scan_interval: 100
        slave: 1
        input_type: input
        scale: 0.1
        address: 12
        data_type: int16
      - name: "Rücklauf Kessel FATR"
        scan_interval: 100
        slave: 1
        input_type: input
        scale: 0.1
        address: 13
        data_type: int16
      - name: "Volumenstrom Solar S"
        scan_interval: 100
        slave: 1
        input_type: input
        scale: 0.1
        unit_of_measurement: l/min
        address: 35
        data_type: int16
      - name: "Kollektortemperatur 1 TSA1"
        scan_interval: 100
        slave: 1
        input_type: input
        scale: 0.1
        address: 38
        data_type: uint16
      - name: "Betriebsstunden Kessel"
        scan_interval: 100
        slave: 1
        unique_id: sensor.betriebsstunden_kessel
        input_type: holding
        unit_of_measurement: h
        scale: 1
        address: 27
        data_type: uint32
      - name: "Anzahl Starts Kessel"
        scan_interval: 100
        slave: 1
        unique_id: sensor.anzahl_starts_kessel
        input_type: holding
        unit_of_measurement: 1
        scale: 1
        address: 29
        data_type: uint32
influxdb:
  host: 192.168.1.67
  port: 8086
  database: homeassistant
  username: homeassistant
  password: xxxx
  ssl: false
  max_retries: 3
  default_measurement: state
  include:
     domains:
        - sensor
what`s with the config?
