As the title says i used to to send it via mqqt and owntracks but since the latter changed its configuration it no longer works.
I want to stick to tasker as a method in order to process the location, due to its flexibility
Any ideas?
Any ideas?
May I ask why you don’t use the official app for location?
I want to update my device location every 2 minutes when a certain condition is met, how is this possible with the HA application?
You may want to try this: https://companion.home-assistant.io/docs/core/location#sending-an-intent
