How to send notifications for DWD weather warnings
I do not see any errors, also in my case notifications are not triggered every 15 minutes.
You can replace my condition by checking particular attributes if they are changed.
Example
condition: template
     alias: Warnung änderungen prüfen
      value_template: >-
        {{ trigger.from_state.attributes["warning_" ~ repeat.index]["event"]
                    != trigger.to_state.attributes["warning_" ~ repeat.index]["event"] }}
In this example, notification will be only be sent out, for example if “FROST” is changed into “GLÄTTE”.
Of course you can add ‘or’ condition and check multiple attributes.
Are you sure that notifications are sent to your mobile device every 15 minutes?
Just received another notification after turning the automation on:
this:
  entity_id: automation.sicherung_notify_weather_warning
  state: 'on'
  attributes:
    last_triggered: '2025-03-01T13:12:29.729219+00:00'
    mode: queued
    current: 0
    max: 10
    friendly_name: 'Backup Notify: Weather warning'
  last_changed: '2025-03-01T12:59:10.956552+00:00'
  last_reported: '2025-03-01T13:12:29.731175+00:00'
  last_updated: '2025-03-01T13:12:29.731175+00:00'
  context:
    parent_id: 01JN8XCF9024QRH1G52VP3W63G
    user_id: null
  idx: '0'
  alias: null
  platform: state
  entity_id: sensor.kreis_sudliche_weinstrasse_aktuelle_warnstufe
  from_state:
    state: '1'
    attributes:
      region_name: Kreis Südliche Weinstraße
      region_id: 107337000
      last_update: '2025-03-01T12:59:08.842000+00:00'
      warning_count: 2
      warning_1_name: FROST
      warning_1_type: 22
      warning_1_level: 1
      warning_1_headline: Amtliche WARNUNG vor FROST
      warning_1_description: Es tritt leichter Frost zwischen 0 °C und -3 °C auf.
      warning_1_instruction: "Hinweis auf \n\_·\_mögliche Frostschäden\n\nHandlungsempfehlungen: \n\_·\_ggf. Frostschutzmaßnahmen ergreifen"
      warning_1_start: '2025-03-01T19:00:00+00:00'
      warning_1_end: '2025-03-02T08:00:00+00:00'
      warning_1_parameters:
        Lufttemperatur: 0 - -3 [°C]
      warning_1_color: '#ffeb3b'
      warning_1:
        start_time: '2025-03-01T19:00:00+00:00'
        end_time: '2025-03-02T08:00:00+00:00'
        event: FROST
        event_code: 22
        urgency: immediate
        level: 1
        parameters:
        color: '#ffeb3b'
      warning_2_name: GLÄTTE
      warning_2_type: 84
      warning_2_level: 1
      warning_2_headline: Amtliche WARNUNG vor GLÄTTE
      warning_2_description: Es besteht oberhalb 400 m Glättegefahr.
      warning_2_instruction: "Hinweis auf \n\_·\_Rutschgefahr\n\nHandlungsempfehlungen: \n\_·\_Verhalten im Straßenverkehr anpassen"
      warning_2_start: '2025-03-01T23:00:00+00:00'
      warning_2_end: '2025-03-02T08:00:00+00:00'
      warning_2_parameters: null
      warning_2_color: '#ffeb3b'
      warning_2:
        start_time: '2025-03-01T23:00:00+00:00'
        event: GLÄTTE
        event_code: 84
        urgency: immediate
        level: 1
        parameters: null
        color: '#ffeb3b'
      attribution: Data provided by DWD
      friendly_name: Kreis Südliche Weinstraße Aktuelle Warnstufe
    last_changed: '2025-03-01T12:59:09.774760+00:00'
    last_reported: '2025-03-01T12:59:09.774760+00:00'
    last_updated: '2025-03-01T12:59:09.774760+00:00'
    context:
      parent_id: null
      user_id: null
  to_state:
    state: '1'
    attributes:
      last_update: '2025-03-01T13:14:09.596000+00:00'
      warning_count: 2
      warning_1_type: 22
      warning_1_level: 1
      warning_1:
        event: FROST
        event_code: 22
        urgency: immediate
        level: 1
        parameters:
        color: '#ffeb3b'
      warning_2_type: 84
      warning_2_level: 1
      warning_2:
        event: GLÄTTE
        event_code: 84
        urgency: immediate
        level: 1
        parameters: null
        color: '#ffeb3b'
    last_reported: '2025-03-01T13:14:09.638052+00:00'
    last_updated: '2025-03-01T13:14:09.638052+00:00'
    context:
      parent_id: null
      user_id: null
  for: null
  attribute: null
  description: state of sensor.kreis_sudliche_weinstrasse_aktuelle_warnstufe
I will try to change the condition and compare it to the code @dominik4545 has used. I have completely lost track of where I have to look for errors in which section of the code…but thank you for your help so far!
Quick update: seems like the weather warning with conditions from @dominik4545 work best in my case. The code from @alanmilinovic certainly makes sense for many, but in my case it was perhaps too demanding to function. User errors on my part have certainly also played a greater role. Anyways, thx guys for helping out and having so much patience with me :slight_smile:
