How to send TTS reply from Voice Assistant to a separate speaker and be able to change it in the UI
Basic rundown of what I’m working with. I have a bunch of ESP32-S3’s with mic’s that I’m putting around the house. I have in ceiling speakers in most rooms and google mini’s in the rooms without them. I’d like to be able to select the speaker (media player) to use in the HA UI instead of hard coding it in the ESP.
Yes I know I can add this to hardcode it like this:
  on_tts_end:
    - homeassistant.service:
        service: media_player.play_media
          entity_id: media_player.nest_mini
          media_content_id: !lambda 'return x;'
          media_content_type: music
          annouce: "true"
It seems like there should be a way to make a virtual speaker or media_player in the ESPhome config file and have a selector in the UI. Even if I needed to hardcode a list of all of my speakers in the yaml that would be better than maintaining 20 different files - one for each speaker.
Anyone find a way to do this?
hi i use this automation to redirect assist audio out
alias: "ollamaspeak"
description: ""
triggers:
  - trigger: conversation
    command: "{question}"
conditions: []
actions:
  - action: conversation.process
    metadata: {}
      agent_id: conversation.llama3_2  #change this
      text: "{{trigger.slots.question }}"
    response_variable: rep
  - set_conversation_response: "{{ rep.response.speech.plain.speech }}"
    enabled: true
  - action: tts.speak
    metadata: {}
      cache: false
       media_player_entity_id: your speaker entity
      #media_player_entity_id: "{{ states('input_select.changeout') }}"
      message: "{{ rep.response.speech.plain.speech }}"
      entity_id: tts.piper
mode: single
if you have multiple speaker you can create an input-select helper with your media_player entity
comment this line
uncomment this one
#media_player_entity_id: “{{ states(‘input_select.changeout’) }}”
change “changeout” by the name of the helper you just created
And how can you not output sound to the M5Stack Atom Echo speaker?
you can create an automation to cut the sound if an other speaker is selected for exemple
alias: Test select
description: ""
triggers:
  - trigger: state
    entity_id:
      - input_select.changeout
    to: null
conditions: []
actions:
  - if:
      - condition: not
        conditions:
          - condition: state
            entity_id: input_select.changeout
            state: media_player.proto_assist_mdp_assist
    then:
      - action: media_player.volume_mute
        metadata: {}
          is_volume_muted: true
          entity_id: media_player.proto_assist_mdp_assist
mode: single
or don’t use the speaker part in your esphome assist, the speaker part is optional
I didn’t understand “or don’t use a speaker in your echo assistant, a speaker is optional”. In the M5 Atom Echo, the output goes directly to the speaker. Your automation sends the sound to my speaker and then to the M5 Atom Echo’s speaker. media_player.media_stop - can’t solve this problem?
sorry, i wasn’t clear
speaker:
  - platform: i2s_audio
    i2s_audio_id: i2s_out
    #name: mdp2
    dac_type: external
    i2s_dout_pin: GPIO04
    sample_rate: 48000
  - platform: mixer
    output_speaker: big_speaker
    source_speakers:
      - id: announcement_spk_mixer_input
      - id: media_spk_mixer_input
  - platform: resampler
    output_speaker: media_spk_mixer_input
    output_speaker: announcement_spk_mixer_input
media_player:
  - platform: speaker
    media_pipeline:
        speaker: media_spk_resampling_input
        num_channels: 1
    announcement_pipeline:
        speaker: announcement_spk_resampling_input
        num_channels: 1
voice_assistant:
  microphone: mic
  use_wake_word: true
  noise_suppression_level: 2
  auto_gain: 31dBFS
  volume_multiplier: 1.9
  speaker: big_speaker      ################### delete this
  on_listening:
    - light.turn_on:
        blue: 1
        red: 0
        green: 0
        brightness: 100%
        effect: Pulse
in your esphome yaml you don’t use the speaker in voice_assistant: … , the speaker is only used by the media_player entity.
I made this automation and everything works the way I wanted it to.
And of course, your automation! That is, everything that the firmware does, two automations do, but you don’t need to reflash anything!
alias: "M5Stack Atom Echo: Stop when starts playing"
description: Automatically stops the M5Stack if it starts playing
triggers:
  - entity_id: media_player.m5stack_atom_echo_fd623c
    to: playing
    trigger: state
actions:
  - data:
    action: media_player.media_stop
mode: single
With your automation you will not bé able to use the m5stack media_player with anything but if it’s good for you then perfect. Have fun😁
I am using an Apple HomePod mini. The idea was to disable the sound output in m5stack media_player.
Thank you for your brilliant idea. Your automation works like a charm but I’ve just updated my atom echo to the newest firmware with continued conversation and the automation breaks this feature :frowning: I’ve tried to modify it using continue_conversation attribute to loop with conversation.process until it’s false. But I don’t know how to wait until first “iteration” ends. Have you tried experimenting with continued conversation? Sorry for my poor english. I hope that you’ll understand it :slight_smile:
hi, first thank you, and no not yet , but now i’m curious can you give me the link of your new firmware?
I’ve got it on device view. It have appeared near the “firmware” button and I was able to upgrade automatically without manually downloading it. I’ve had some problems with it, because after pressing “firmware” button there was wait cursor for the long time, but after resetting echo couple of times the firmware eventually have shown. So I haven’t seen any link to the firmware. But I’ve found it on Google now. It’s version 25.6.1 and you can get it here: Releases · esphome/wake-word-voice-assistants · GitHub
i will look into it
did you try without the automation? if yes what happen?
It’s just works as expected. When I ask it to add a timer without stating the timeout it asks for it and after announcement led is on after some 0.5 sec and I can tell it the timeout. But the sentence spoken by ai must end with question mark. To make it happen add “If you are expecting a follow up response, always put a question at the end of the last sentence.” to the prompt. I’m using Extended Open AI integration and it just works every time. I’m suspecting that conversation.process in automation is working in some other way than when you just speak to the device. You may see it looking at device view. In automation the state is “processing” and normally it’s “listening” and “answering”
Small followup: I’ve managed to change briliant yaml version published in another thread so its fully working with continued mode and adds many new properties to echo device in HA including option to link external media player ! :slight_smile: Here is my post in this thread. All credits go to original yaml changes author :slight_smile:
