How to set the voice assistant to Portuguese? Every tutorial say that I need to select the main language on the top to view the available options for stt/tts for that language but I only see these options:
What am I missing here?
Thank you
Thank you
What components for stt and tts do you use?
The language is indeed configured in this menu. Are you setting up a pipeline from scratch or editing an existing one?
I’m adding a new pipeline:
I have speech-to-phrase and piper installed, since this instance is running on a rpi4.
Whatever I select on the first dropdown is automatically selected for the stt and tts, and there is no Portuguese anywhere.
I also tried changing my entire home assistant to Portuguese (which I don’t like because it’s easier to follow tutorials in English), without success.
your list of available languages is very similar to the current information from the addon (although S2P already supports more languages)
Try temporarily installing another STT service, for example whisper
Never mind, after installing Whisper I had to restart Home Assistant to see the Portuguese option.
I still haven’t been able to set speech-to-phrase to Portuguese though. If I select the language, “speech-to-phrase” option is grayed out (although their GitHub page shows that they support Portuguese).
The add-on downloads the February release (the latest one to date).
If you are not ready to look for workarounds yourself, wait for the update.
